FiveFourStillTickin
- First Name
- Justin
- Joined
- Feb 21, 2023
- Threads
- 1
- Messages
- 4
- Reaction score
- 0
- Location
- Richmond, VA
- Vehicles
- 2023 F-150 CrewCab 6.5' Lariat 501A PB, 2004 F-150 Supercab Lariat
Hi all, long time lurker. I've been soaking up the PB knowledge shared on this forum by Snakebitten, HammaMan, et al.
I've run into an odd one that I haven't been able to find any existing threads about. While the truck is in motion and transitions to electric power, the READY indicator in the instrument cluster disappears. No warnings, no loss of power steering/HVAC/infotainment, etc. Applying enough pedal to get the gas motor restarted and, voila, it's back.
I've had this happen 4-5 times over the last couple of weeks and some common themes I can think of:
I've been through seemingly typical PB 12v SOC trials-and-tribulations (can elaborate if needed), and just recently replaced 2nd OEM under-hood battery with a NAPA and the under-seat aux with a new OEM (researching a better replacement, but had it on hand) and did a BMS reset. This was several weeks prior to the first time I've noticed READY's disappearing act. I did get a slew of OTAs after battery replacement/BMS reset, most recently the 10.1.0 update.
Logically, I'd fathom a guess it's related to a cold hybrid battery pack, but if that's the case I'd hope the engine wouldn't let the truck go into all electric mode until it's up to temp. Plus the electric motor IS still working while READY has disappeared, so maybe barking up the wrong tree there...
Given the manual's definition of the indicator, it's a bit unsettling that it turns off while the vehicle is in motion:
HYBRID ELECTRIC VEHICLE INFORMATION INDICATORS E293827 When you start your vehicle, a green READY indicator light appears in the instrument cluster letting you know that your vehicle is ready for driving. The engine may not start because your vehicle has a silent key start feature. This fuel saving feature allows your vehicle to be ready to drive without requiring the gas engine to be running. The indicator remains on when your vehicle is on, whether the engine is running or not, to indicate your vehicle is capable of movement using the electric motor, gas engine or both. Typically, the engine does not start unless the vehicle is cold, a climate control change is requested or you press the accelerator pedal.
Trying to figure out if any of y'all have ever experienced this and/or if this is a symptom of a bigger issue to come.
- Truck remote started with key FOB, let it run ~10 minutes before getting in and pushing start button. READY pops up per usual on pushing START/STOP button and engine still running
- It's cold out - first couple of times I noticed it was in the 20s. Though this most recent occurrence it was almost 50. Happens both stationary in Park if engine is warm enough for HVAC demand and while driving
- Once I've been driving for 10-15 minutes or more, and engine comes up to full/near full temp, further transitions to electric only doesn't seem to trigger it. Parking for <30 minutes then driving again, hasn't happened
