tbinmd
I wish Ford would allow seperate CCD suspension settings rather then grouped into the drive mode. Make it like the Raptor. I want the normal drive mode with sport suspension setting.
I too was a little confused by the descriptions VS the AsBuilt values that came with the truck. The redundancy across different descriptions is confusing too.I am putting this on the list. Should have the truck soon and once I get a few miles on it I’ll give those settings a try. Surprised that the baseline weights are so high. I have the 145” WB and my module listing has the same weights as yours initially had. Keep up the good work!
If you monitor the PIDs for the VDM module you will see the various values change when you switch modes.@Snakebitten, how do the factory drive mode settings affect CCD behavior? Is Sport mode "tighter" than Normal? Does Tow/Haul raise the rear when weight is added to bed or rear bumper (trailer tongue weight)?
Just curious and figured you may know!
Amazing, thank you!If you monitor the PIDs for the VDM module you will see the various values change when you switch modes.
I'm not saying I actually have sorted out what the values actually mean ? yet, but it's starting to make some basic sense.
There's too many pids to populate the gauge screen with so I just loaded the front left corner pids.
Here's what they look like:
Yea, ALL that is just for one damper. ?
But honestly, I think I could narrow it down to just the ones I have circled.
When you switch from say Normal mode to Sport Mode the most obvious value change is "damper current Amps". It switches from a static .6A to .7A
It appears that the circuitry that controls the damping valve(?) operates at very precise micro-voltage? (Afterall, it IS a common 5Volt computer module)
For example if you apply normal brake pressure, you may not see the amperage increase, but if you apply enough brake pressure to introduce nose dive, the amperage increases. Thus increasing the damping (resistance to compress)
The VDM_LF_D_PRLL_RES_G in mOhms pid is the one I really want to know more about. It's by far the most active, electronically speaking, and it's the one that varies the greatest between driver modes. It operates very fluidly within a range, and the range changes dramatically between say Normal VS Sport.
I've just gotten started with the AsBuilt edits to the VDM module, but I believe the correlation that I am looking for is the AsBuilt values relationship to VDM_LF_D_PRLL_RES_G
There's gotta be some fellas that understand this stuff way more than this old man just poking buttons to see what happens. ?
Although I admit to being hopelessly fascinated.
Oh, as far as the truck raising its own height if a load is put on it? It's not that kind of active suspension. I don't think it's possible to adjust height without an air suspension component. This is a very basic active damping approach. Basically it's only capable of variable "resistance" to compression/rebound.
I agree.If anything I think my CCD is a touch floaty when not in sport mode. But def rides nice.
I actually haven't yet. That's why I want to hold off on dialing the damping in further until I get the Antisway addressed first.Snake: what rear sway bar did you install? My boat is no problem, but it might be helpful when pulling my horse trailer.
It's a heavy truck, with a solid rear axle, a crude rear suspension, and heavy rear leaf springs. That's pretty much whatcha get.Hey so I’ve got a 2022 Lariat powerboost, long wheel base with about 4000 miles on it. Has anyone with the CCD shacks felt that the ride of the truck was harsh and bouncy? We test drove 2 short bed Supercrew trucks before we ordered and I remember thinking how smooth the ride was. Those did not have the CCD shocks. From day 1 my truck is rough over bumps and and seems to almost shutter on bigger ones. Not even close to how the test trucks rode.
I’m wondering if the wheelbase has a little to do with it. Almost seems like the electronic control of the shocks isn’t active at all or something, like they never activated them at the the factory or dealer.??Anyway, I’m open to any comments from people with expletive with these shocks. Thanks!
Did you get an answer to your question from Helwig? What did you end up doing? I put an anti sway bar on my Dodge Dakota many years ago, and I'm not sure I ever noticed a difference. Do they make a noticeable difference on an F150?Are you saying that a solid rear axle truck can't ride substantially better than they come equipped oem?
Of course I don't think that's really what you mean.![]()
Please upload your file again. I try to download it and I'm told the file is corrupted.I have attached my exported gauges and the user-defined OAR pid.
Note that the forum only allows certain file types to be uploaded, so I changed the extension of the file to pdf.
You will need to change it back to stg?
Also, the gauges may not "scale" perfectly on your device because of differences in the resolution between devices. I have the gauges highly customized on that one dashboard that is my primary for driving. They are nested tightly together with overlap, so you might have to "drag & move" some of them slightly?
