2021 XLT LED Tail Light Swap
lomax0990
US, WV
2021 F-150 XLT 502A
I’m assuming lots of people have done this and I’ve done some research. I was hoping someone could answer a few questions for me.
1.) Can I use the OEM LEDs from any model (I.e Raptor,Tremor, etc)
2.) Can you recommend a harness? It seems a lot of people use the harness from Gray Goose.
3.) Is it just a basic swap and some forscan updates? Do I need to swap the blis modules?
Thanks in advance for any help/suggestions.
schn4x4
2021 xlt supercrew
very easy swap, yes need to swap your modules to new tail lights, BarryT82 member has great deal on tremor led taillamps new, I know there are some people that offer jumper harness,
i used a factory tail lamp harness , jesse-infotainment help me get oem tail lamp harness using my Vin # ( little more work installing tail lamp harness but worth it, knowing it factory set up
there is a thread on this forum giving you all the forscan changes also
Ford F-150 2021 XLT LED Tail Light Swap IMG_1349
Ford F-150 2021 XLT LED Tail Light Swap IMG_1350
lomax0990
US, WV
2021 F-150 XLT 502A
Thanks for the info. So I’m assuming those in the picture are the tremor LEDs?
ReverendQ
Kevin
SoCal
Website
www.linkedin.com
For the $ and the looks, the morimotos are hard to beat. The reverse lights suck balls to put it nicely though. Easily rectified with HFT rock lights attached to the hitch crossmember.
https://www.morimotohid.com/Ford-F-150-21-Morimoto-XB-LED-Tails
Ford F-150 2021 XLT LED Tail Light Swap 1706411348681
Agreed
