2021 Lariat Battery Replacement Questions (Dealership vs. Self)
KYT
Louisville, KY
2023 F-150 Lariat
How about "IT manager"
Actually, the battery Monitoring Sensor and the Electrical Energy Management system sense and use both voltage and current (amps) to determine the charging curve (as with most sophisticated chargers, both volts and amps are variable when charging).
Perhaps of interest is the attached, which though specific to the 2.7 / 3.5EB, is the same for the 5.0.
Currently reading this PDF, very much appreciated. Good info, everyone should give it once over at least.
I think this is the important detail regarding changing the battery, regardless of the capacity.
Battery Replacement
If the vehicle battery is replaced, it is very important to perform the battery monitoring system reset using the diagnostic scan tool. If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory. Additionally it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions
endzone_truck
endzone_truck
Shlomo
Ontario
2021 F150 Lead Foot Grey Lariat 5.5
Those of you who have purchased an H8 at Costco, is there a part number you can relay? I'm afraid that if I just ask for an H8, they won't know what to sell me.
Thanks in advance!
PJRNM,
just search the website. Any H8 will do.
