Big Cam
Nick
North Dakota
2022 Ford F150 Tremor 402a
Support Engineer
Does ur DRLs are on when the switch is in automatic position? I get mine to 60% but i sont remember if the DRLs should be in when in auto.Also got any idea why bambi Mode doesnt work in my car? I did it through forscan but they don't work with high beams on
DRL's should be on when the switch is set to auto and there is enough light for the headlights to NOT be on.
As for Bambi mode, my only suggestion is to double check that you modified the correct line.
Imo
Melchior
Poland
F-150 2021 3.5l ecoboost
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 20221123_140414
Doesn't work for me :/ Drls comes on when you put car in Drive or Reverse :D
I was able to do the windows and brighten the drls but bambi Mode still don't work for me. Maybe I need to wait till it's dark
GloverF150
Jerace
UT
22 F-150 Lariat
I have a 22 Lariat I just got finally last week. Have made several changes in forscan so far. Couple questions, I cannot get it the go into the as built of the IPMA it goes to 27% and then errors out. I can get into the other ipma module that allows you to select options. I was able to complete glare free with this style. Also wondering if there is a way to keep my 22 cameras in the split screen on at speed. It switches to full screen when I go above the speed in front mode. And can you get more of the side cards added?
Imo
Melchior
Poland
Have same issue. Maybe cable is bad? Do you have recomended cable? I thought it was because of my error but if you have same issue.....
GloverF150
Jerace
UT
22 F-150 Lariat
I’m not sure I don’t have the exact cable they recommend for sure so it could be that. I think it’s weird I can get into the selection style one but not the as built style.
Heathen
Lowcountry
22 XLT
Any reason not to use 2.3.48 version? 2.3.49 keeps closing on my laptop but, previous version (2.3.48) seems to work fine. Have not linked to vehicle yet. Thanks for any info.
Nightshade
AJ
Alberta, Canada
Any of you have a MacBook Pro with a M1 Pro chip and got Forscan to work ?
I was able to instal Windows and Forscan with Parallel Desktop, but I can't make my OBDLink EX to connect to Forscan.
Thanks for your help.
Yup I'm using my MacBook Pro 16" with M1 Max; honestly wouldn't mind a Windows computer, just love the Mac better. Had no issues using FORScan through Parallels and with a OBDLink Ex. You need to make sure Parallels is detecting your OBDLink Ex USB input to Parallels and not to Mac. Have used it on my truck, my work trucks, and all my buddys' trucks as well.
Je.Bedard
Jerome
Quebec, Can
F150 Powerboost 2022
Yup I'm using my MacBook Pro 16" with M1 Max as I absolutely HATE windows laptops, too slow and bulky. Had no issues using FORScan through Parallels and with a OBDLink Ex. You need to make sure Parallels is detecting your OBDLink Ex USB input to Parallels and not to Mac. Have used it on my truck, my work trucks, and all my buddys' trucks as well.
yes I’ve done it and it won’t work…
I admit that I can expense almost anything IT related, so I'm fortunate to not have to decide my own personal Mac/Windows debates.
If the budget($) is apples/apples ?, the Windows laptop isn't "slow and bulky".
Sorry, couldn't resist.
I admit there's some Harbor Freight tools in my barn. Especially if I only need them for rare occasions. I just don't expect as much from them as I would a Snapon......... since I did ante up for the good stuff.
Buyer2021
central TX
retired!
I gave up and bought a cheap new windows laptop for FDRS, Forscan, BMW programming, and BMW aftermarket audio equalizer software.
Yep, like it or not the reality is there's some very useful Windows software (and peripherals) that just play nicer and are easier to use on a native Windows machine.
Imo
Melchior
Poland
I just got the recommended cable today and I'm able to enter IPMA module, so bad cable is the reason.
Still bambi Mode doesnt want to work in my truck. Anyone have any suggestions?
GloverF150
Jerace
UT
22 F-150 Lariat
Can I get the front camera to stay in split screen at speed on a 22? It goes to full screen at speed.
Imo
Melchior
Poland
I have question for pros in forscan. Which module is responsible for airbags? And how can I delete airbags error? Tried to jus delete codes but airbag icon doesn't go away. Maybe I need to restart module responsible for airbags? But which one is it and is it safe?
merc
James
Alabama
TBD
After doing the Glare Free Menu, I noticed that my lights are almost always on now. I keep my light switch on auto. Did one of the settings adjust the sensitivity of the light sensor?
