Infotainment
Doug
Orlando, Florida
2023 F-250, 2021 F-150
Hey Ford truck owners! ?
If you drive a 2011 or newer Ford F-150, F-250, or F-350, and you're still dealing with clunky aftermarket trailer brake controllers, it’s time for a serious upgrade.
We offer A 100% factory OEM Integrated Electronic Trailer Brake Controller, designed to work seamlessly with your Ford’s existing system. No complicated wiring, no dealership programming, and no guesswork—just true plug-and-play convenience.
? Why Choose the OEM Brake Controller?
✔ Factory-Fit & Fully Integrated – Blends perfectly with your existing interior and shows trailer data in the gauge cluster
✔ Control On the Go – Customize trailer brake gain with built-in plus/minus buttons
✔ Faster Stops, Safer Hauls – Boosts control on downhill grades by automatically applying trailer brakes
✔ Pre-programmed – Activated in under 25 minutes with our included OBD Genie F-TBC programmer
✔ Set It & Forget It – Save unique settings for different trailers
? Things To Know
  • Use the plus/minus buttons to raise or lower gain (the braking force sent to the trailer). Hold to adjust continuously.
  • Recommended testing: On dry pavement, test at 20–25 mph using a gain of 6.0. If trailer tires lock up → reduce gain. If trailer brakes seem weak → increase it.
  • Visual display appears in the Truck Apps menu in your instrument cluster (not on the radio screen).
  • When a trailer is not connected, the display will read “Trailer Disconnected.” Once connected, it shows your gain setting and a real-time braking graph.
? Why This Upgrade Matters
Don’t settle for clunky aftermarket hardware bolted under your dash. This OEM upgrade delivers factory performance, better control, and a cleaner install, no dealer appointment needed. Whether you’re towing heavy loads, trailers, campers, or equipment, this is one upgrade you’ll wish you made sooner.
? Have Questions?
Our team is here to help before, during, and after installation.
? [email protected]
? 1-855-636-6287
? Live chat at Infotainment.com
CompleteTruckNewbie
CO
2023 F150 XLT sport 4x4 3.5L
I installed such an OEM controller on my own, which required FORscan changes, so I can see why someone would want the convenience of having everything delivered in one package, including the programming dongle.
LCMM55
Larry
Myrtle Beach, SC
2021 F150 Hybrid Powerboost
? Things To Know
? Have Questions?
? [email protected]
? 1-855-636-6287
Very cool factory fix
805Greg
Santa Ynez, CA
2025 F150
Two questions pertaining to Step 1F.
1) "Put Vehicle into the run position." Just to be clear, turn ignition on, but do not start the motor, correct?
2) "Remove the genie and give the vehicle a sleep cycle." What is a "sleep cycle"?
Beef_Stew
Aaron
2022 F150 XLT sport CCSB 5.0
Auto Body Tech
Does the “trailer disconnected pop up every time you start your truck on the 21+ trucks?
Infotainment
Infotainment
Doug
Orlando, Florida
Yes, you got it. :)
Sleep cycle is when you are out of your vehicle, you hit lock on your fob then wake away. After about 5-10 minutes the vehicle enters a sleep state. Next time you unlock the vehicle brings it out of the sleep state. From lock to unlock is a sleep cycle.
tshephard
Tim
RVA
2023 F-150 XL 4x4 5.0 hitch chrome
If anyone is still looking, learning Forscan is worth it for the "Global Windows". Walking towards or away from truck, even low level fob can open or close all windows.
