J3TL4G
- Thread starter
- #1
I did some research on recommended service intervals for my new 2025 F-150 Tremor 5.0L V8 - mostly because, quite frankly, the Ford recommended intervals seem way too long.
This truck will be a street queen. Virtually no towing (other than towing my golf cart in the bed, which is hardly considered towing). Pretty good mix of highway and city miles. 4WD will probably never be used unless I go up north to go skiing. I am in Arizona though, so the summers are tough on fluids.
Here is what I came up with:
Every 5000 Miles:
• Oil & Oil Filter Change (Pennzoil Ultra Platinum 5W-30 & Motorcraft FL-500-S)
• Engine Air Filter (As Needed)
• Fuel Additive (Amsoil P.I.)
Every 10,000-15,000 Miles:
• Cabin Air Filter
Every 30,000 Miles:
• Transmission Fluid
Every 60,000 Miles:
• Front & Rear Differential Fluid
• Transfer Case Fluid
• Engine Coolant
• Spark Plugs
Every 2 Years:
• Brake Fluid
Is there anything I should adjust or add? Obviously will follow Ford's recommended schedule in addition to. I was debating whether or not Transfer Case Fluid should be changed every 30K like the Transmission Fluid?
Thanks!
Every 5000 Miles:
• Cabin Air Filter
Every 30,000 Miles:
Every 60,000 Miles:
• Engine Coolant
• Spark Plugs
Every 2 Years:
• Brake Fluid
Thanks!
