Wipers hitting A pillar?
dre276
andre
NJ
2018 F150XLT, 2021 F150 XLT 302A Lead Foot
I have an XLT 302A package. The other day, in the rain, I had the wipers on max, and while driving, I kept hearing a ticking sound. Figured that it was the driver side wiper just slightly hitting the A pillar. Does anyone else have this issue?
Jus Cruisin
Tim
Metro Detroit
Very retired
Adjust them..... 5 or 10 minute fix. Or take time and swing by your dealer if it's out of your skill set.
chrisp993
Bloomfield Hills, Michigan
'21 F150 Platinum, '15 Audi S4, Spec Iron Mustang
As Jus Cruisin indicated, it should be a quick fix - when "at rest" does the wiper seem to sit a little high? You need to remount it a little lower to move the sweep of the wiper blade slightly anti-clockwise. Google, or check out: Gen 13 Wiper Adjustment
dre276
andre
NJ
Inside the wiper, there's a metal tab (that's removal) that sets the wiper position from factory. I was able to remove it and adjust it accordingly but was wondering if anyone else had the same issue to see if its a common problem with the 2021.
Jus Cruisin
Tim
Metro Detroit
Very retired
It just gets the wipers close so the assembly guys install them quickly, consistently. All the knurles aren't exactly lined up perfectly. Which is why adjusting them is easy.
KartRacer25
Richard
San Diego
Is that passenger arm supposed to look all bent ant twisted like that?
Maybe its the lighting, but I just looked at some pics from the lots and those dont look quite the same, they do have slight bend toward the glass, like to maintain pressure on blades but not quite like this I think.
Ford F-150 Wipers hitting A pillar? 1616890956227
fordfam
Sky
Indiana
2021 Ford F-150 Sport
Hey guys, first post here. I purchased my 21 f-150 Sport last April and it has just over 22000 miles on it. My drivers side windshield wiper is now just slightly hitting the A pillar. I have removed the wiper arm and adjusted it down, but in order to get it down far enough to not hit the a-pillar the wiper arm now rests at the very edge of the plastic cowl just below the wiper arms and will probably make contact with it. I have removed the wiper arm and repositioned it about a dozen times and it seems it is either too low or too high and there is no in between. Am I doing something wrong?
The drivers side windshield wiper has about a quarter inch of play in it when at resting position whereas the passenger side has almost zero play. I fear this could be the culprit and it could be a more in-depth fix. Any ideas or similar experiences? Thanks all!
Additionally, I just checked the alignment marks which are in the windshield. The wiper arm is right at those alignment marks when at resting position, but wiper arm still hits a pillar when on full speed.
BHunted1
Sumner County TN
Dealer just replaced both mine few weeks ago. Driver side started doing it too. Haven't had time to mess with it.
fordfam
Sky
Indiana
Mine is at the dealer today. I’ll update with what they have to say about it.
fordfam
Sky
Indiana
Update: truck went to the dealer today. Was there only a few hours when the service writer called and said it was ready. I asked what the tech had to do to correct the issue and was told the wiper blade was adjusted. Wife goes to pick it up and calls me on the way home. The wiper blade is still hitting the a-pillar. I can hear the “clicking” noise it makes through the phone. Now I have to call them and tell them it isn’t fixed and take it back again tomorrow. If only they had actually checked their work they wouldn’t have a come-back.
Ken
Pittsburgh
96 f150 XLT, 2019 Jeep Grand Cherokee, 2020 Subaru Ascent
So I took mine in about a month ago and same thing. Adjusted the blade and then told me it was good. Go figure it wasn't and I'll have to take it back again. I believe it's within my skill set to do what the tech has done, but I'm not sure repositioning it is enough of a remedy.
fordfam
Sky
Indiana
Mine went back to the dealer today. They ordered a wiper motor. I was thinking this could be the issue because the drivers side wiper had more “play” in it than the drivers side did. I’ll let you know if this is a fox or not. The part is supposed to be ordered and arriving in the morning.
fordfam
Sky
Indiana
Update: I picked up my truck from the dealer yesterday. They replaced a wiper motor. I have not yet verified that the issue is fixed, but they say that it is. Hopefully this helps anyone else experiencing a similar issue even after adjusting the wiper blade.
BlackWolf
Alain
Miami
Ford F-150
PM
Good morning.
Guys something new on this issue? Happening to me on my 2022 as well.
