Windshield Washer Fluid Sprayers Weak - 2021 Platinum
collinvon
Collin
Minnesota
981 Boxster S, 2021 F150 Platinum
Is anyone else having an issue with weak windshield washer fluid sprayers? Mine barely reach 6" or so up onto the windshield, so I end up wasting a ton of fluid to adequately clean the windshield.
nsbreeding
Neal
Louisiana
F150 Lariat 2021
Mine stopped completely, but there was a mouse nest right next to my battery and it had chewed through the line (I had the hood open less than 10 days before so it was busy). but mine does cover the windshield (now that is has been repaired)
collinvon
collinvon
Collin
Minnesota
Thanks for the reply. At least it sounds like it's a fixable problem and not a model-wide issue.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Mine hit right in the center of the windshield at the highest. I wonder if the spray nozzles/jets just need adjusted some?
Jus Cruisin
Tim
Metro Detroit
Very retired
In the past you could adjust them. Mine are fine so I haven't needed to look into it.
collinvon
collinvon
Collin
Minnesota
I'll have to look into this. They do seem to be aimed at the middle of the windshield, but don't have the power to reach it.
Plattypuss
PA
2021 F150 Platinum PowerBoost Rapid red
I have a platinum and mine works great. I’d say have the dealer take a peak at it.
PB2021
Rob
2021 F150 Lariat Powerboost
I'm finding mine a little weak (or jets misaligned). Spray covers bottom half of glass only.
collinvon
collinvon
Collin
Minnesota
UPDATE: A squirrel chewed a small hole in the lines..
