Will changing rear block (going higher) mess with ccd?
TDHAWKS
Trevor
Omaha
RAM Laramie 22
My 502a has ccd, therefor most coil-over sets aren't going to work. A local shop suggested the readylift 2" front spacer. I currently have 2.25-2.5"" of rake and if I load the bed, it'll end up dead level if not lower than the front with the stock rear block. I was going to take out the factory block 1.25-1.5" and replace it with a 2.5" to give it a little rake so it doesn't appear nose high. If I do the 2" in the front with the 2.5" in the rear, am I going to mess up anything with the ccd or should it be good to go? Will it ride like crap going higher in the rear or the same as it will retain more of the factory rake? I was also going to go a tad heavier on the rubber with my new set to help it feel more planted as opposed to the SL tires than are currently on it.
