Will 22x10 -18 wheels on 285/55/22 tires rub?
flynnstone
Matt
Arizona
‘22 F150
Curious if anyone has leveled a new 4x4 and ran this wheel tire setup without issue?
Calson
Monterey CA
Turn the wheels all the way to each side of the truck and check the clearance at the front and rear of your current tires. Then check the added radius and width of the new tires and you will know if there is going to be a problem.
Stangman570
Florida Panhandle
2022 F150 XLT Supercrew 2022 F150 XL Single cab
Electronics Engineer
-18 and you for sure will rub. I'm running a -12 and I had some trimming to do leveled at 2.5in. Had to cut 3in off the rear crash bars so I could flip them and then some light trimming on the plastic block that's under with liner
BRINK WHEELS
MIKE
MIAMI, FLORIDA
Website
brinkwheels.com
2024 XLT
Will Rub with that offset. This is why we went with 22x10 +12
Works with no lift :cool:
