Whipple 3.0 pulley questions.
spc_gibbs
lahoma Oklahoma
Whipple Supercharged 2021 Ford F-150 XLT Supercrew
LOX attendent and CDL truck driver.
If I change to a 3.875 pulley will I need a retune on stage 2 whipple? The belt is too tight with the 4.0 on with a ten percent overdrive. Just keeps shredding belts and it it really hard to get the belt on it.
Sigma1914
TJ
South Florida
2023 Rocky Ridge Ford F-150 XLT 5.0L V8 Coyote
I’ve called Whipple myself about this and you can to just to confirm what I’m about to say. So technically whenever you are changing the air to fuel ratio or timing? Yes. BUT after speaking with Whipple. Per Whipple customer service. It is safe with the Whipple canned tune to go down one pulley size because the ECU and variable timing will learn how to adjust to the extra 1 pound of boost going from size 4.0 down to 3.875. They said since it’s only 1 pound of added boost that it’s ok. So I pushed the needle a little bit and asked if I could go down to a 3.75 size pulley from a 4.0. They said that would be the lowest, safest pulley I could go down to. Any lower would risk engine problems and possible damage. BUT since I had purchased and planned to install my Stainless Works Hi Flo Catted Long Tube Headers. I went ahead and not only dropped down from a 4.0 size pulley to a 3.75 but I also went with a Reische 170 degree performance thermostat, new pulley belt and a tune from Ken over at Palm Beach Dyno.
spc_gibbs
spc_gibbs
lahoma Oklahoma
My tune is hpt out of dell performance in Lebanon Tennessee. I am just trying to make a bit easier to change the belt. Having the 10 percent overdrive make hard as heck to change belts plus I think it’s to tight. Had to change the tensioner already broke it with a new belt and shredded the belt now the old belt is on there but it’s about toast and am waiting on one to get here.
spc_gibbs
spc_gibbs
lahoma Oklahoma
If I buy a new pulley does it come with the screws or do I reuse old ones? I am new to this. I can’t seem to find a pulley with the screws or bolts.
grnsnake97
Acworth, GA
2021 F-150 XL
When I installed a new pulley I just reused the bolts. My Whipple came with a 3.875 pulley from the factory and I installed a 3.75 when I went got a custom tune from Oz.
spc_gibbs
spc_gibbs
lahoma Oklahoma
Thank you for the info ordered the new pulley today. Whipple said I didn’t need to get a new tune for one size down.
Mikemann0
Johnson City , Tn
2024 F150 XL SCSB
So going one size down 3.875 to 3.75 no tune change needed but same belt ? And at what pulley size change does require a new belt if not , Thanks.
