Hullguy
- First Name
- Jim
- Joined
- Oct 14, 2020
- Threads
- 7
- Messages
- 488
- Reaction score
- 468
- Location
- Weymouth, MA
- Vehicles
- 2013 F150 FX 4
- Occupation
- Retired Union Electrician
It doesn’t work this way! Travel Trailers that run on 30 amps are only using 120 volts. The bigger trailers with 50 amps run on 240 volts. The 240 volts is split into 120 volts at the trailers electrical panelThanks for the replies. But I’ve used adapters (dog bone) before that enabled me to plug my 50 amp RV to a 30 amp plug. While that does allow me to plug in, if I were to draw more than 30 amps, I would flip the circuit breaker. Seems that the same would occur with the PB. I’m not an electrician but it seems to me that if the PB can deliver 240v at 30amp (7.2 kw) that it should also be able to deliver 120v at 50amp (6 kw). 6 kw would be enough to power two rv a/c units. I’m wondering if there is a way to upgrade the the circuit breaker at the PB to 50 amp?
