Underhood fuse box removal
kd-
Were you able to locate a broken wire, and find what was wrong? I just did the same exact thing, but my tailgate actuator went out instead. I also ended up using the lower grommet when I couldn’t get a fish stick through the upper one also. I have an appt at the dealership, but it isn’t until Jan 26, 26 and my warranty will likely be up by then.
Yes, though in my case is was a blown fuse (F212) to the aux battery the PowerBoost models have, see my post here.
I don't think power for the tailgate actuator runs through here, I'd check the RGTM fuse, which is F37 in the 2021 service manual I have.
Here's all the high current fuses:
HIGH CURRENT FUSES
FuseAmpsCircuits protected
F3660
Gas
Diesel
Direct Current/Alternating Current (DC/AC) inverter
F103100
Police
Auxiliary stud box
F201300
Gas
Diesel
Generator
275
HEV
Direct Current/Direct Current (DC/DC) converter control module
F20450Power Steering Control Module (PSCM)
F205125
Diesel
Glow Plug Control Module (GPCM)
F208125
HEV
Engine cooling fan relay 1
Engine cooling fan relay 2
F211300
Gas
Diesel
Not used
F212125
HEV
Auxiliary battery 1
F21350Power Steering Control Module (PSCM)
kd-
Also - I'm not a warranty expert, but in my experience as long as the issue is documented as a problem before the warranty expiration, it should be covered under warranty. I'd make sure you have some kind of written documentation of the issue, somewhere.
Similar threads
