UnderCover ArmorFlex 2020 vs 2021
RawFord
Rodney
2018 f150/ 2005 GTO
Console operator
Just ordered a cover for my truck. I’ve been reading that 2020 model fits the 2021s. But I see the part numbers are different, Ax22020 and ax22030. 2020 cover is $200 cheaper. Should I cancel and buy 2021 cover?
Kurtis
Arkansas
21 F-150 Platinum
Guessing you have the 6'7" bed based on those part numbers? I have the 5'7" bed and just checked the part number the shop installed on mine, and it was the 2021 5'7" AX22029. I have heard that the 2020's work on the 2021's and there have been people on this forum that have swapped their old covers to their new trucks. May be worth giving UnderCover a quick call to understand the differences.
billybob
2021 F-150 XLT 302A, 2012 Focus SEL
EE
I did read that the Bakflips are different part numbers because the width changed slightly, although most people swap them fine.
RawFord
Rodney
2018 f150/ 2005 GTO
Console operator
Dang I was trying to get the cheap way out lol. I also saw some vendors using the same part numbers. I’ll prob just cancel and order the “correct” part.
NoReins
Pennsylvania
I technically have a 2004-2014 F-150 Undercover Tonneau Cover on my 2016 and it fits fine. The only thing i needed to do was to move the 2 middle mounting brackets down 6-inches, because of something in the bed got in the way, and i didnt have enough room to mount the bracket. Once i get a 2021, i will probably re-use that tonneau cover on the 2021.
So it is probably that same type of situation between a 2015 and 2021 Tonneau Cover. There is probably a slight change that was made, so Undercover made a 2021 part number
