JGDallas
- First Name
- Jaideep
- Joined
- Oct 18, 2025
- Threads
- 10
- Messages
- 56
- Reaction score
- 24
- Location
- Frisco, TX
- Vehicles
- F150 STX
- Occupation
- Self Employed
From all videos watched about swapping transmission fluid (without dropping pan) on our 14th Gens, I have seen two very different styles. Which do you prefer, and why? I am very curious so please detail as well as you wish.
1. Drain 5-6 qts of old fluid and fill same amount of fresh fluid. Drive 20 miles. Then drain 5-6 qts of the old/fresh mix, and fill 5/6 qts of fresh oil. Result about 75% fresh oil in the trans. DONE.
2. Drain 5-6 qts of old fluid and fill same amount of fresh fluid. Start the truck for 20-30 seconds during which roll gears from park to neutral to reverse to drive to reverse to neutral to park. Turn engine off. All this in 20-30 seconds. Then drain another 5-6 qts from the pan, and fill back 5-6 qts fresh oil. Here's the claim: About 20-30 seconds is all it takes for oil from pan to go through the torque converter, then through the cooling lines and return back to the pan. With fresh oil from pan feeding into the torque converter and transmission pushing used oil into the pan. The second drain and fill then causes the transmission theoretically full of fresh oil.
The second method sounds more scientific to me IF
1. Fresh oil from pan is really chasing the old oil out (without mixing) of TC and transmission cooler lines into the pan.
2. As fresh oil is leaving the pan towards the TC, old oil is coming into the pan from the Transmission cooler lines. Isn't oil mixing in the pan before the entire "fresh oil" in pan get to go into the system?
