LarryIT
- Joined
- Sep 3, 2022
- Threads
- 1
- Messages
- 19
- Reaction score
- 5
- Location
- UP Michigan
- Vehicles
- 2022 Ford F150 Lariat
I recently towed my boat and put it in the water at the marina for the season. When I got home, I disconnected the trailer and parked the truck in the garage. Started truck up the next day and got a few different alarms (Rear Park Aid Deactivated Trailer attached, Reverse Brake Assist Not Available, Trailer Left Turn Lamps Fault Check Lamps, Cross Traffic Alert Deactivated Trailer Attached). So something thinks trailer is still attached. Brake controller says that there no trailer attached. I tried pulling the negative battery terminal for 20 minutes, pulling fuses 91 and 42. No change in condition. Other symptoms include fast turn signal flash pace inside the the truck, but normal flash outside. Also no lines on backup camera when backing up. If this is a common problem can someone point me in the correct direction? This is a 2022 F150 Lariat 2.7L 502A with very few options. Thanks
