Towed trailer with 200miles on truck
grayscale
lost
cars
hello all,
Can you tell me if im being paranoid or is there anything I should actually do?
TL;DR - I towed a 5K lbs trailer with my truck at 220miles on it for 40 miles or so, did I screw up or am I just over thinking it?
So this is my first truck, first new vehicle, etc and at the dealership my salesman told me I did not need to break in my truck before towing stuff. I didn't think to google to or check the owners manual to about a break in period so on day two of ownership a friend needed help getting a trailer towed to his home to get some work done and I offered to help.
Should I be concerned that I caused any issues or damage to the truck towing before the 1,000 mile break in period? Truck had about 220 miles on it at the time. It is a 3.5L with max tow. I didn't beat on the truck or drive it hard while towing. Trailer + kubota total weight was 5,000lbs or less. Round trip was about 40 miles total with some hills
I feel like the transmission shifts slightly harder or messier today at around 330miles but could that just be due to the break in period in general?
Am I being stupid and paranoid for no good reason and need to just chill out or is there a legitimate reason for concern?
Thank you all in advanced and my apologies for my stupidness here
Rod507
Georgia
2021 Ford F150 XLT Powerboost
Ideally No… but with that being said I don’t think such small trip would be detrimental to the Powertrain. You should be okay… as far as hard shift, it’s a known issue with these trucks, specially Powerboost. side note: as a maintenance though I’d recommend the first oil change to be at 1k and 4K thereafter with Full synthetic.
grayscale
lost
cars
Thank you Rod for the reply, I had heard the Powerboost were a bit hard shifting in the transition between electric and ICE; but I wasn't sure about the regular 3.5L Ecoboost which is what mine is. I will definitely replace the oil at 1,000miles like you have said
Thank you again for the reply
Rod507
Georgia
you’re welcome.
Ive seen others mention shift issues with non-powerboost.As I’m sure you’ll do, make sure to address it when taking it for oil change!
As for oil… don’t let them tell you you can go 10k+ miles on full synthetic?? LOL
Capt Obvious
Longwood, Fl
21 F150 Lariat SUper Crew 500a 3.5 EB Max Tow
I can’t speak for an F150 but we take brand new 3/4 and 1 ton trucks and hitch really freakin heavy bumper tow and gooseneck trailers to them the very next morning and everyday until we get rid of them. Chevy, Dodge and Ford they seem to last until the replacement interval of 120 to 150k miles depending on the condition of the rest of the truck.
grayscale
lost
cars
Thank you for that info, that makes me feel a lot better, I have wondered what companies and especially rental companies do, I can't imagine they are all following rigorous break in processes and they get bought on the used market without a thought all the time
Capt Obvious
Longwood, Fl
Yeah, they’re fine, the transmissions have fine and these are all gas trucks for us now. We used to use diesels but they honestly broke too much.
Tomatoboy
Maryland
It’s always ideal to follow the break-in procedure. Sure, there’s always some small chance you’ve contributed to some premature wear. However, you’re probably fine. You didn’t massively stress the vehicle and it was 200+ miles in. It’s not like you took it off the factory line with the rings barely seated and ran the powertrain at max towing capacity for 2500 miles. I wouldn’t stress over it, just follow the break-in the rest of the suggested period.
Deleted member 17130
Guest
I've been in Sport mode since like 100 to 200 miles and keeping it out mostly out of the overdrive gears except on highways, putting the truck through consistent acceleration habits because the transmissions on these can be moody if you're kind of all over the place and constantly switching drive modes. Don't over think it.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
The whole 'break-in' procedure/timeline is mostly just for the engine, to get the rings seated and worn in properly. There is little need for any 'break-in' on a transmission, rear axle, drive line. Not following the 1,000 mile rule, isn't going to hurt anything that you will ever notice. Don't worry about it.
You would do more damage to the engine not changing oil often enough, than towing something prior to 1,000 miles.
Aron
Aron
Civil Engineer
Maybe? Regardless, Ford recommends not to do it for the first 1000 miles in the owners manual. Take that recommendation for what you will.
DBL R
Jarred
Washington
2021 F150 powerboost
PA
Same. All our farm trucks 3/4 diesels towed fairly heavy loads almost straight off the dealer lot. Not sure of the apples to oranges comparison here. That being said, I followed the ford manual for break in just in case.
