Tire rotation and TPMS reset
Kanuck
Winnipeg, Manitoba
Retired Electrician
Sort of similar to the content here... I found a set of OEM take-off wheels and tires. The seller said the TPMS's have been removed. Am I hearing correctly, all I need to do is buy 4 new TPMS (where, prefer OEM?) for each wheel/tire, install them, and mount the new set, then eventually the truck figures it out?
The TPM's have to be the correct ones for your truck. I got mine from a local tire shop, installed. Not sure if it would learn by itself, but I just go to my dealer and one of the service writers comes out at reprograms the truck. Takes less than 5 minutes to do.
TexasTruck
Scott
2022 Ford F-150 STX BAP
I fix software bugs!
Thank you @Kanuck , I'll give a service writer a call on Monday... l have learned that at least the 2021 and 2022 use Motorcraft TPMS-68 sensors which transmit at 315 Mhz. I called my local OEM parts counter, $83 a piece - wow.... I see a bunch on Amazonian but I'm a little leary about their quality.......
Kanuck
Winnipeg, Manitoba
Retired Electrician
I did a $70.00 each installed cash deal with the tire shop. I figured, even off Amazon, I would still have to get them installed. I just had one fail, took the truck back to the tire shop, they checked it out and replaced it free of charge. That alone, made it worth the extra few dollars. And now that I think about it, the spare must not have one. Hummmm
