Temp display on trailer TPMS?
SomebodyInGNV
Gainesville, FL
'21 F150 4WD 301A 3.5L w/ HDPP
My '21 Job 1 XLT HDPP came with a yaw sensor. The rear wire harness for the 12-pin socket had only 2 wires so I replaced it with part # ML3Z-13A576-PK, in which the 12-pin socket is fully connected. That enabled me to install a trailer camera/TPMS kit (part # LC3Z-1A189-A). Everything works after updates with FDRS and editing IPC to display the trailer tire menu.
My analog instrument displays only PSI, where other F150 owners show tire temps, as well. The example I've seen on this forum is on a digital instrument panel. I don't know if that (digital vs analog) determines whether or not temps can be displayed.
Does anyone have insight into trailer tire temp display configuration? Can I display trailer tire temps, at all? If so, what more must I do?
Thanks for any suggestions.
