New Hampshire Tailgate light bar question
JDG78
jon
NH
2022 F150 Lariat
Has anyone installed a light bar and only have it light up for reverse and brakes. I do not want the running lights or directionals to activate.
thanks
gh8toes
Traded my '19 platinum for a 2024 King Ranch
I'm considering using some of the $785 Ford is giving me on program 24B57 on a light bar, but was just going to let it do it's thing. You might want to contact Putco and ask if you could get your desired result by cutting a couple of wires on the install.
5.XOH
Austin, TX
2023 RCSB 5.0 XLT 4x4
Bump - similar question, I’m kind of looking for just a reverse light bar. Any suggestions?
travisN000
Travis
Oregon
2021 F150 Powerboost CCSB
when I wanted to add lights to a bike rack, I used a flat tow wire harness that plugs in between the driver's tail light and harness and modified it to get the reverse lights working (added wire and 5-pin connector).
I bought the cheaper 'used' version from amazon since I was going to modify it (If you read the reviews, you will see that some get returned d/t incorrect pin locations, which is an easy fix, expecially if you are going to modify it anyway):
https://www.amazon.com/dp/B0BRNZG9HL
