Swapping OEM power running boards for AMP boards?
Wmflyfisher
Wesley
Inlet Beach FL
2019 F150
Has anybody done this? If so, is it pretty straightforward? 23 platinum with factory power running boards. Would like to swap them for Amp boards due to them dropping lower.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Just go find some take off super duty power running boards if lower is what you're after, plug and play. That's what I have they go lower and are the exact same spec as the AMP boards if I'm correct. If you want something in the middle, find some 15-20 F150 power boards as they go lower than the 21+'s, but not low as the super duty boards.
Facemelter
Andy
22 Space White 3.5 S-crew. 89 Mustang Notch
Will model year 15-20 fit 21+ ?
Jesse-Infotainment
Jesse
2024 F150 Lightning
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Yup, that is what I have on mine essentially. Any newer aluminum cab styles boards will work across the board, so 15-20 F150 and 17+ Super Duty boards as they haven't changed.
Wmflyfisher
Wmflyfisher
Wesley
Inlet Beach FL
2019 F150
My concern is the plug and play part. Are all 2015+ OEM boards the same wiring and plugs? Want to make sure I get something that works especially if I’m ordering off eBay or 2nd hand etc
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Yep, all the same plug
motivology
DK
Arizona
2021 Ford F150 Platinum Powerstroke
Realtor / Entrepreneur
Interesting. How much lower with SD running boards? My Dad has a SD running boards and they don’t look much lower than mine...
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
If you have the factory power boards why would you want to go aftermarket?
astrand1
Alex
Studio truck driver
I need them to deploy lower.
Ahh. I wondered what the issue was. Is your truck lifted? My buddy has the factory power boards and I thought they come out at a really good level but he is at stock height.
Wmflyfisher
Wmflyfisher
Wesley
Inlet Beach FL
2019 F150
Yes with 35’s. The older version deployed lower which was much more comfortable stepping on and for others as well.
