Speakers making popping noise upon entry
Rickam
Rick
Cleveland
2024 King Ranch 71 Mach 1 63 Ford Galaxie XL
Speakers making popping noise upon entry. has anyone experienced a popping noise when you open the door. I have the B&O system. Otherwise everything works fine no issues with the radio at all. ?
rugedraw
Javier
Miami
Auto Sales
Every single time, or randomly? Any static noise coming from the speakers after the pop?
Rickam
Rickam
Rick
Cleveland
Quite often no other issues of stereo speakers work fine it’s just when you open the door you hear popping on the speakers just as you open the door does not continue
rugedraw
Javier
Miami
Auto Sales
Well, the same SSM released recently may apply to your case even though your symptoms are different from what others have described:
SSM 51663 2021-2023 F-150/Expedition - Pop Noise And/Or Static In Speakers At Start Up
2021-2023 F-150/Expedition may exhibit a pop noise and/or static in the speakers at start up that cannot be turned down or off using the audio system controls. To correct the condition, reprogram the audio digital signal processing module (DSP) to the latest software level using the Ford Diagnosis and Repair System (FDRS) diagnostic scan tool. For claiming, use causal part 18B849 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
Make an appt with your dealer, tell them about the popping sound and mention this SSM. There is a software update that may fix it.
Rickam
Rickam
Rick
Cleveland
Thank you I will present that to them next time I take it in
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there, I'd be happy to look into your F-150 concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
Same here. This is a result of a recent software update. I have the basic B&O system in a '21 Job 1 Lariat. Pops on entry.
RickBullotta
Rick
Pennsylvania
The software update actually caused it.
rugedraw
Javier
Miami
Auto Sales
Several people have installed that DSP update and have reported no issues. That is mighty strange.
RickBullotta
Rick
Pennsylvania
I suspect it has something to do with which sound system is installed, since there are multiple options. Mine is the "standard" B&O.
Sd1719
Sabrina
Kamloops, bc
F150, ford edge
Our 2021 ford f150 does this as well. Does a software update fix it? We have had so many issues with it needing to go into the shop for software updates. Super frustrating.
RickBullotta
Rick
Pennsylvania
I thought this went away with the latest software update, but it didn't. Mine still has a popping sound on entry ("regular" B&O system).
mikeoneone
Woodstock
2023 Ford F-150 Lariat
Pimp
Does anyone have a resolution to the "speaker pop on entry"? I have this issue AFTER the latest software upgrade. The dealer hasn't been able/willing to help.
lcrain
Lawson
'21 F150, '95 911 c2, '97 miata, '98 M3/4/5
Has anyone resolved this? I also get some static sounds from the seat speaker (I think) when leaning back in my seat. The lumbar extended makes the static go away but still annoying!
MTBF150
RRH
Hood River, Oregon
2023 F150 Lightning
Mine does the same thing. I've had my truck into the dealership 6 times to fix the problem with no solution. APIM and DSP replaced, along with all the programing updated. Now they are saying they need to remove all the interior and find the "wire/ground/connector" that is causing the issue. They say it could take up to 3 weeks? This is crazy. Since this keeps happening to others, I'm hoping someone has found a solution.
