SpaceWhiteF150
Montgomery, Texas
Most of us take pride in our trucks! Show off where it lives and how you clean it up! I know some of yall have awesome garages!
Ford F-150 Share your detailing / garage setup! IMG_3457
I just have a simple wall mount pressure washer and an assortment or detailing supplies! And a griots polisher set!
Ford F-150 Share your detailing / garage setup! IMG_3458
My rig lives happily tucked in the barn!
Flash69
Austin, TX
2022 F-150 Platinum
Here is my detailing setup
Ford F-150 Share your detailing / garage setup! IMG_7626
CarbonMark
WA
2024 F-150 XL Regular Cab
I did the full Obsessed Garage wall mount path a few years ago.
Had to open up the wall to run a 20A outlet for the pressure washer (can pull just over 15A with a foam cannon), and hot/ cold water lines.
I was also teaching my self to TIG weld, so I built the external plumbing feeding the pressure washer and De-Ionization Spotfree system out of stainless steel.
Ford F-150 Share your detailing / garage setup! IMG_5231
Ford F-150 Share your detailing / garage setup! IMG_4436
Ford F-150 Share your detailing / garage setup! IMG_4363
Ford F-150 Share your detailing / garage setup! IMG_4286
G_Money
North Carolina
F150 Lariat Powerboost
What kind of lights do you have in your garage? I'm debating barina vs led retrofit fixtures where I can change out the tubes when they burn out.
CarbonMark
WA
I used Maxlite 4’ fixtures with direct wire ( 120V AC), 4k LED bulbs in my garage. Since the fixture takes any direct wire, T8 style LED bulb, they are easy to replace if a bulb ever burns out.
If I ever moved, I’d absolutely install these again!
Link to the fixture (shop around to find the best price): https://www.ledlightingwholesaleinc.com/LSS2XT8USE4803-p/lss2xt8use4803.htm
scuba
Dallas, Texas
'22 F150 Lariat PB Mid Front Bench, 2013 E350 4x4
High dollar vacuum station (thx to Walmart shopvac + one of those remote-outlet on/off switches). The goal was to have 2 kids be able to work together to vacuum the truck. Mission accomplished -- I could go to sleep each night listening to their little voices: "On! Wait, Off! Ok, ON! ok, Done, I mean OFF!"
Ford F-150 Share your detailing / garage setup! 2024-05-08 10_14_42
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
Im chomping at the bit to post pix of my new shop. We wont move until daughter graduates higshcool. So previous owners are renting it back from us. June 10th is move-in date....
(Not my truck)
Ford F-150 Share your detailing / garage setup! 20240322153514617476000000-o
Ford F-150 Share your detailing / garage setup! 20240323044214671824000000-o
Ford F-150 Share your detailing / garage setup! 20240322153248082520000000-o
Ford Motor Company
Official Ford Account
Ford
Dearborn
Most of use take pride in our trucks! Show off where it lives and how you clean it up! I know some of yall have awesome garages!
We love to see it! Thanks for sharing with us. :)
JCsTruck
Worcester MA
That garage is EPIC! ?
