Running board retracting suddenly
iceman77
Pete
2022 Ford F-150 Platinum
The driver side running board suddenly retracts after opening front driver door. Last time it happened it almost caught and dragged my foot under while stepping out of the truck. Has anyone seen this issue before ? Not that this happens every time, but had this happen couple of times already. This is dangerous and can get one injured.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there! Send a private message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’ll look into this for you. Thank you!
Zyvin
SC
2021 F150 Crew, FX4, Lariat
They will retract if the motor senses an object, or resistance (corrosion, dirt, etc.). The first thing I would do is just look under there to see if there is anything obvious, and maybe hit the pivot points with some lube, and see if it helps.
If it’s retracting just because the door opened (i.e. someone else gets out, they are extended for several seconds and then it retracts as soon as you open the door), that’s a different issue than it just going out and right back in.
Platinum Peasant
West Sacramento
Mine had the same issue, replacing the motor seemed to fix the problem.
iceman77
Pete
Mine haven’t done this for months now (knock on wood). Did you take it to the dealer for replacement ? Was it covered under warranty ?
Platinum Peasant
West Sacramento
Yes and yes. They went straight for the motor apparently. Not sure why. But it worked (so far).
