Running board questions
LFRoss
Ross
Louisville Ky
2021 XLT CREW CAB 5.0
Forklift mechanic
Hello I bought a used 21 crew cab xlt a month ago and being a used truck I knew that it wouldn’t be imperfect condition. But it was in really great shape minus some typical rust. I live in Kentucky but the first owner was in Michigan based on the info from the car fax listed on the dealers website when I was looking at the truck.
Today I noticed a pretty good size scratch down the side of the passenger running board and as I was looking at it I not too hard but firmly hit the end cap and it popped right off. It looks like it was glued on. And the scratch continues under where the end cap was. Does anyone know of the end caps are just glued on to the running board or was this “repaired” at some point Also I feel like I would have noticed this decent sized scratch on the running board when looking at the truck. I recently took it through a brushed Carwash, could that have taken any touch up paint off?
jhelrey
MN
Someone glued it on... I highly doubt the factory uses wood glue.
Blueshound
Dave
Connecticut
Mine (exact same) tore off too, not sure how. There's one bolt. Picture shows part number. I found a replacement for about $6 on ebay including the bolt and clip.
LFRoss
LFRoss
Ross
Louisville Ky
Forklift mechanic
Thanks. I saw them on eBay as well. How was it buying from there? Never bought anything from eBay?
EcoB259
GB
22 XLT S Crew
I have a new set of take offs if your interested
LFRoss
LFRoss
Ross
Louisville Ky
Forklift mechanic
Where are you located and how much are you wanting? Will they come with the mounting brackets? Mine are starting to rust on the forward side of the brackets
EcoB259
GB
22 XLT S Crew
$200
I am in Florida until May. Then I drive back to IL for the summer months.
LFRoss
LFRoss
Ross
Louisville Ky
Forklift mechanic
$200
Your don’t happen to drive through Louisville Ky on your way back to Illinois do you?
EcoB259
GB
22 XLT S Crew
I normally leave Atlanta early and head up 24 through Paducah but I can take 75 to Lexington 64 thru Louisville. And onto IL.
nvabill
Virginia Beach, Va.
2022 F-150 XLT, Jeep Wrangler Rubicon
Do yourself a favor and buy yourself a take off set of running boards from a Lariat. That’s what I did, much nicer looking and wider than the cheap XLT boards.
https://www.ebay.com/itm/1939684458...b-__VmIQLW&var=&widget_ver=artemis&media=COPY
LFRoss
LFRoss
Ross
Louisville Ky
Forklift mechanic
nvabill
Virginia Beach, Va.
I didn’t know there was any difference in running boards other than the extended boards
Yes, the XLT is not as nice as the Lariat’s or as wide unless you get the extended boards. Just look at the photo in the listing, I can already see you have the narrow standard running boards.
