Rubbing on 295/65/20
Ntx150
Nic
texas
Hello all,
I have a 2021 F150 on a Bilstein 5100 Level, fronts set at max height. I just switched from my worn out 285/65/20 KO2s, to 295/65/20 KO3's and am experiencing rubbing which I believe to be on the UCA's - What width hub spacers would you all recommend to alleviate this?
Thanks -
Ford F-150 Rubbing on 295/65/20 IMG_6628
NDakBoom
Carrington, ND
2023 F150 Sport Appearance
Hello all,
Thanks -
You should do a search for that tire size. There are a few strings of posts on this subject. My gut tells me you should be looking for 12mm wheel spacers to get an effective +30mm offset.
TMicallef
Terry
Trenton, MI
2022 F150 XLT
Automotive Supervisor
Why did you switch from 285/65/20s? Did you experience any rubbing anywhere at all with those? My 22' is leveled and I plan on trying that size in Toyo AT IIIs with a factory +44 offset stock wheel.
Are those factory wheels you are running?
Graygoose2021
Oklahoma
Sales
Check front lower portion of air damn. I had +20 on a 295, and rubbed there, some trimming fixed it.
Graygoose2021
Oklahoma
Sales
Yea stock rims, should be fine. But spacer may be, if not, air dam would be my first check.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
i'm running this as my set up.
Ford Performance Bilstein Set at 2.5"
Brink Insurgent 20x9 et18
Toyo Open Country AT3 295/60/20 E
i was hitting the spot @Graygoose2021 mentioned. only in reverse near full lock. I was going to trim it but it didnt rub often enough to convince me to waste the time and effort. When i went with the Tremor skid plate kit, that piece gets removed anyway.
