Right Fog Light LED DRL Flickering
TJSparky
WA
Has anyone had any issues with the DRL LED fog lights flickering? It is just the DRL LED beam in the right fog light that is doing it. I tried unplugging it and plugging back in with no positive results. May end up taking it to the dealer as I think it’s the light assembly itself but just wanted to see if others experienced the same thing.
FrankThompson
Frank
Sebring, FL
Solutions Architect
Have you done the Forscan mod to increase the brightness of the DRLs?
TJSparky
TJSparky
WA
Yes I did. I just turned them back to stock to see if that stops the flickering. Will report back in a bit.
KBKEITH
Are mods done via Forscan traceable by a dealer?
TJSparky
TJSparky
WA
So I changed the DRL values in Forscan back to stock brightness and let it run for 5 min.. no more flickering that I can see. I will watch it for a few days to see if that actually fixed it or not.
FrankThompson
Frank
Sebring, FL
Solutions Architect
So there are 2 ways to do the drl forscan mod. The one you did which I think forced it to 100% and another that allows you to set the "dim" percentage to a higher value. Many who had the flicker issue changed their value to 75% or so and the flicker stopped. They also reported no observable difference in output.
I'll see if I can find that main thread. I still plan on reverting mine (the same one you did) and doing the alternative as I feel it's the better approach.
FrankThompson
Frank
Sebring, FL
Solutions Architect
TJSparky
TJSparky
WA
OK... This is interesting as I was using the original BCM change
726-42-01 0303 - 0101 - 057D Changing to 0202-xxxx-xxxx
I appreciate the info as this appears to be what I have been experiencing.
Going to try the 75% change and see if that helps
EDIT: 75% still caused flickering for me but 50% seems stable.
I appreciate your help on this.
Icecoldak
Steve
Alaska
2019 F-150 Limited
Curious is there any diff on the 2019's cause I changed mine to extra brightness and I have not had any issues at all!!
FrankThompson
Frank
Sebring, FL
Solutions Architect
I believe in the 13th gen at one point they were 100% brightness from factory. They got complaints and adjusted it down. My current theory is that the 13th gen hardware is made to ensure support for 100% brightness, but since the 14th gen was never designed to operate at 100% the hardware may or may not work as expected.
