Rear axle Squeaking noise 2022 PowerBoost
Flight047
Arian
Miami
2022 f150 lariat hybrid 3.5L
just started hearing a squeaking noise while driving coming from the rear axle. I have an appointment to go back to the shop . anyone Else experienced this noise?
garner75
California
2022 PowerBoost
This just started happening to me too! Also a 2022. For the mechanically challenged, Snakebitten, are you suspecting the much talked about sheered axle bolt issue?
Well I was wanting to eliminate that first!
Flight047
Arian
Miami
Let's see what they say . Today I don't hear it much but it's annoying as heck.
garner75
California
2022 PowerBoost
While driving around this week with my windows rolled down I made the realization that the squeak occurs when the internal combustion engine (ICE) turns off. And it is precisely when the ICE turns off. I can't tell if the squeak also occurs when the ICE turns on. For reasons relating to wind noise, etc. it's just been harder to tell. Flight47, any chance this aligns with what you're observing too?
wayne b
Wayne
Long Beach, CA
2021 Lariat PB
I'd immediately pop the center cap, or remove the wheel, and confirm the axle bolt is intact.
For those of us plagued by the axle issue - what's the best way to do this? Is there a specific (plastic) tool, or YT video you'd suggest? It seems like keeping the caps off and routinely confirming the bolts are still there is probably the best way to know if the problem has repeated after replacement.
Flight047
Arian
Miami
Mine happens more when I start breaking . This morning was very quiet. Only drove 2 miles so I'm guessing it gets louder as I drive more. I'm dropping it off tomorrow to check on it. I will keep u guys up to date.
Natesbluepowerboost
Nathan
Dc
22 f150 powerboost lariat
I have a 2022 powerboost and am experiencing this issue as well. It’s a sustained squealing screeching coming from the rear axel area whenever I depress the accelerator or depress the brakes. The noise is only while in motion and only when depressing either pedal. Has anyone found the cape of this yet? Is it ok to drive?
Flight047
Arian
Miami
Yes they found some broken piece back there . The part took a week to arrive. Drive carefully and take it to them asap.
