Radio Preset Pages Acting Funny
cool rod
Rod
Central Florida
2021 F-150 Powerboost Platinum, 2013 Mustang
Recently my radio has been acting up. I have 6 pages preset but it will only scroll through 3 pages and then returns to page 1. I've tried resetting the number of pages and then going back to 6 pages but that didn't change anything. I can manually select any page but I can't scroll to get there. Has anyone had this problem and how did you fix it?
Thanks
schn4x4
2021 xlt supercrew
Having rge same issue, Seem to happen after last updae
Still looking for a fix
Just annoying hope a patch update will fix it
Fix one bug get another LOL
I guess I'm boring with using only one screen of presets. ?
NzCanuck
Glenn
2021 F150 Hybrid
Well my 2021 would change stations whenever you turned right, so since my truck is still not fixed by Ford Canada, you probably hzvd the same gremlins. Sorry to say
Jesse-Infotainment
Jesse
2024 F150 Lightning
Does it go back to preset one or does it go to the preview channel..
I had the issue and it was a station changed. It still showed the Station name in the preset but if you selected it the channel wasnt active anymore.
The bridge for example. Has moved I believe. SO if you have that as a preset when you go to select it it will go to preview.
To find out manual select ever channel and verify they all are working.
This is the only thing I could think of. May not be it but worth checking
cool rod
cool rod
Rod
Central Florida
Thanks. I have that preview channel issue too. And Sirius seems to change stations in my preset list whenever it feels like it.
I think gremlins must be right. ?
PaulGrun
United States
2022 F-150 XLT
I had this same issue with the Bridge. Whenever I scrolled to the Bridge I would instead get a preview channel and strange scrolling behavior. The solution was simple; just reprogram that preset to a valid channel.
cool rod
cool rod
Rod
Central Florida
I finally found a cure for this problem: reset the radio. After that you have to add back any channels you want to have preset and it works fine and best of all it stops pushing the Sirius Preview channel on you. You also lose temporarily your connected services, but you just go back and reconnect them. Also it says you lose BlueCruise for up to 14 days but I haven't bothered to dig into that.
To reset the radio just go to Settings_General and scroll to the bottom. Choose Factory reset.
It's worth the effort if your radio is driving you crazy.
cjrazus1
AZ
F350 DRW
Cool Rod I don’t know what year truck you have (or if it matters?). I have a 2024 and the sync 4 has been fine since May when I got the truck.
I had all 6 pages of presets programmed but as of a few days ago I cannot scroll in sequence page 1-6 (or vice verse). It will go 1-2 or 6-3. I looked at your fix but when I hit the reset option you spoke of, it says it resets the modem. No mention of radio. Any ideas would be appreciated
