Powering A Rented Tow-behind RV
cool rod
Rod
Central Florida
2021 F-150 Powerboost Platinum, 2013 Mustang
We're going to Arizona on a roadtrip and thought we might rent a tow-behind RV for a few days when we're there. I have a PowerBoost with the 7.2KW generator and would like to know what I need to buy to connect power to whatever we rent. I have plenty of extension cords but I think I might need something heavier to plug into an RV. We want to spend a couple of nights off the grid and enjoy the stars at night. Thanks
SWillier
Sonny
ARVADA
2013 F150 & 2022 F150 on order
Architect
Something like these. you might need an extension cord depending on where you park your truck vs where the rv plug reaches. It probabbly won't reach from the back all the way to the truck if parked in front.
4 prong generator to whichever RV plug.
For a 30a RV:
https://www.amazon.com/Snowy-Fox-Generator-Adapter-Handle/dp/B07MJSX63C/ref=sr_1_4?crid=3U4BQ2J89F3MB&keywords=4+prong+generator+30a+rv&qid=1648848234&s=automotive&sprefix=4+prong+generator+30a+rv,automotive,90&sr=1-4
For a 50a RV: (I think. Mine is 30a)
https://www.amazon.com/Snowy-Fox-Ge...tor+50a+rv&qid=1648848396&s=automotive&sr=1-4
Aron
Aron
Civil Engineer
The rental will probably come with some length of power cord, but you may need an extension. Probably worth waiting to buy it until you know what the power requirements are going to be, since there are several types. You may also need an adapter to connect the rv cable to the truck.
cool rod
cool rod
Rod
Central Florida
For a 30a RV:
Thanks for the info. Cheers
cool rod
cool rod
Rod
Central Florida
Thanks, that makes sense. I'll just see what they provide, if I need something else I'll find it out there.
Arcteryx
RJ
Wisconsin
2021 XLT FX4 Lead Foot Gray
Not sure the specs on a power boost power output. However the power needs over a camper with AC is 30 amps. 50 amp on bigger RVs that have 2 or more AC units.
When I hook up to a 20 amp on crowded campsites I pop the breaker regularely on hotter days.
As for the supplied power adapter with campers is typically 30 feet. I keep a 50 foot extension that ran about $60
UGADawg96
JAX, FL
For a 30a RV:
OP - You absolutely need a 30amp four round twist prong to 3 pin RV plug like posted above. Another option is just a plug that does the same thing. That's what we have, but I'm on mobile so don't have the quick Amazon link. If the trailer is a 50amp, it may be too heavy to pull with a PB. The owner should provide at a minimum a 25' power cord. We carry a 25' and a 25' extension.
Edit:
Camco 55338 PowerGrip 30 Amp 4-Prong Generator Adapter , ORANGE https://www.amazon.com/dp/B00CXAC5MG/ref=cm_sw_r_awdo_1BRFRP0XDWTW4XETYZWM
cool rod
cool rod
Rod
Central Florida
Edit:
Thanks again. I didn't know about any of those adapters and cords, so this was the right place to ask.
grergrer
RV truck
For a 30a RV:
Hi,
Thank you for such a nice info!
