Powerboost RPM using generator
towpro
will
Fl
23 Lariat Powerboost
Not sure I have seen this on the forums, Is this generator an inverter or does it need to run at 3600RPM to come up with 60 cycles per second?
I don't own a powerboost, but I am learing about them (but we do own a 2020 Escape hybred and I did own a 2018 Cmax)
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
Its an inverter.
BRDVPRA
Bryce
Tulsa
2021 F150 2021 Explorer ST
Yep
If Eco idle is on, the truck will run at 1300 to 1500rpm for 2 to 3 minutes to charge the batteries then the batteries will run whatever you are doing until the get low then the cycle starts again. The batteries will last longer than you would think under load. I hope that is what you are asking. If not, let me know!
Swags
SE Michigan
22 Bronco OBX, 2020 F150 Lariat
To elaborate on @mnstang's comment, the engine simply charges the hybrid battery (via an alternator or using the electric motor as a generator, not sure which) which then feeds an inverter (DC->AC) that makes the correct line frequency and voltage for the outlets. Because of this disconnection, the engine can run at whatever speed is needed to make the battery charging most efficient.
towpro
towpro
will
Fl
thanks. I was hoping it did not run at 3600 Full time, or even 1800 engine RPM.
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
If you have Eco Idle ON, it will idle around 1300 rpm. If you have Eco Idle OFF, it will idle at 1000. When I'm sleeping in my trailer overnight I'll set Eco Idle OFF so that the vibrations don't come through the hitch as much. When my trailer is disconnected I set Eco Idle to ON.
