Power source for cell phone booster
Luke Duke
2003 6.0L Excursion Limited, Maybe a 2022 F150
I am planning to install a cell phone booster on my 2022 CC Powerboost. Is there a switched power source under either the driver or passenger seat that I can tap in to? I only need 2A. The alternative is running a wire all the way to the fuse box, which I can do if I need to.
Kanuck
Winnipeg, Manitoba
Retired Electrician
On my 21 XLT, I needed switched power for my dash camera. Got it from the fuse panel on the passengers side kick plate. Use an ADD A CIRCUIT I got from Amazon
Gebildet 4pcs 12V 24V Add-a-Circuit Micro 2 Fuse Tap, Piggy Back Blade Fuse Holder with Wire Harness, 6 pcs Micro 2 Fuse (5A 10A 15A) and Fuse Puller
RGJIV
WNC
’22 702a Powerboost AMB, Waiting for ’25 702a Powerboost AMB
GC
Has anyone tapped into any of the passenger seat harnesses for this. That was my plan, so if anyone has any insight and would like to share, I would be very appreciative.
Thank you,
discothan
SW Michigan
2021 F150 XLT
You could tap into the rear-view mirror power. I did this with an adapter to power my dash cam.
zacko11288
Illinois
2021 F150 Lariet
Engineering
Do you by chance have a link to the adapter you used?
zacko11288
Illinois
2021 F150 Lariet
Engineering
Sure, keep in mind this is for a specific use, deliver power to USB.
Rear-view mirror power adapter
There are other threads about what pins you can tap into on the rear view "plug" to get power/switch etc.
Appreciate it, was planned to use this solution for a USB powered dash cam
