My Lariat has a mind of it's own
HDT05
2024 F150 Lariat 502A FX4 5.0
Hi all
After 8 months of (relatively) trouble free daily use of my truck, I made the mistake of changing some of the settings yesterday relating to folding the mirrors and zone lighting. I went into the screen menu and activated the folding mirrors, and zone lighting. After getting confused about what was going to come on and what was not with the zone lighting I just turned it all off again..... I have no idea what has happened but now I have all sorts of unrelated issues and my truck has a mind of its' own.....
  • Drivers window - today I went to close my drivers side window whilst I was ready to get gas (in park, handbrake on and doors closed) and my window closed then reopened on its' own to about 2 inches. I closed it again then it reopened and kept doing so until I held the button whereupon it just stopped. Then it worked again and has been doing the same thing each time I go to shut off the truck since(I drive with the window down usually). Here is a vid... Can anyone suggest what is going on?
  • I needed to use my Apple Carplay Nav and suddenly the directions appear in the main console and the speed and tacho move/reduce in size. Can anyone show me how to prevent this happening or tell me what I did wrong?
  • Ford F-150 My Lariat has a mind of it's own 2021-12-29 15.05.05
  • I have been driving my truck in 2wd mode during the summer months and when we get rain I switch it to 4A, which I understand to be 4wd as required. Yesterday I had it in 4A and today I start the truck and it is back in 2wd. It seems to be changing on its' own? Does anyone know why?
  • My console preference keeps changing. One minute I have Trip 1 as shown above then the next time I start the truck I have the fuel economy graphic showing or some other random selection. I know this has been mentioned before but I haven't had too much of an issue with it?
  • Finally, (not related to above) but I have some sort of rattle/loose object in the rear that sounds like the brakes rattling or very much to the rear.... is this the exhaust rattle?
thanks all for your help!!!!
Cheers
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
Hi all
Cheers
On the window, do the reset/learn function.
The Apple direction in the cluster is a result of OTA 1.71. I do not know a way to stop it from doing this.
The other I have not suggestion.
RedTXV
Houston, TX
2021 SQ Limited
Hi all
Like suggested, do the relearn process. No big deal.
If you’re using CarPlay nav, the gauges are supposed to reduce in size to make room for info on the dash.
4A shouldn’t reset on start up, it didn’t in my 2016. Now, if you were in a driving mode that put in 4A, then yes, it will resort back to “Normal” mode every key cycle.
Go into configure your view, and make Trip 1 your first selection if thats what you want to see on every startup.
Cant help you with the rattling.
Cheers
See replies above in bold.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi all
Cheers
Hi there. Could you please send us a private message with your VIN and the name and location of your Ford dealer? I'll check into these concerns on my end. Thanks!
HDT05
HDT05
Hi
Thanks for the reply....
  • I understand though through research that you can apparently turn off the Nav option showing. Just need to figure out how and why it suddenly decided to be the default
  • Yes, 4A changes without my input
  • Have already made Trip 1 my default but it doesn't want to play hence my raising it
  • Already going to my dealer to chat about the rattle
Cheers
Wookie
Fulshear, TX
2023 Platinum Powerboost
I had the window glitch and followed the manual's guidance. It said it is caused by something blocking the path. I simply ran my finger along the track and it hasn't happened since.
spud_41
Mountains & Desert
The truck automatically resets to Normal mode which is 2wd, can be nice but can also be annoying. You should have a notification on the dash if you want to revert to the previously used mode if you drove the truck recently but it's not always available.
People covered the other stuff but the directions are a new Carplay feature that Android Auto already had. If you're comparing it to the built in Nav features that take up the center of the dash, Carplay doesn't do that.
HDT05
HDT05
Why does it reset? I was under the impression 4A was the same but just 4wd on demand?
RE the Carplay Nav directions, can it be turned off? I believe the standard NAV one can be...
HDT05
HDT05
Thanks
Will have a close look at it....
spud_41
Mountains & Desert
Probably because it hurts fuel mileage and tears up tires faster when you don't need it. It is essentially all wheel drive, so you're right, 4wd when it needs it. If you run the power distribution view with 4a on you'll see it gives at least a little power to all wheels most of the time.
I don't think it can be turned off, but I like it so I haven't looked into it.
Oxford_Powerboost
Austin
Northern Virginia
2023 F150 Lariat 5.0
4A is AWD. It likely resets for fuel economy, as you’ll get worse fuel economy in 4A. However, I need to check if mine switches back to 2Hi automatically or not. I believe if I select 4A in normal mode and never change the drive mode, it’ll stay in 4A when I restart it.
pkinneb
Paul
Zimmerman MN
So yesterday we had some snow so I turned mine to slippery which engaged 4A later I turned back to normal but had to push the 2h button to get it out of 4A not sure if that helps or not
RedTXV
Houston, TX
2021 SQ Limited
Uhh, you shouldn’t have had to do that. I have not used slippery, but Sport modes engages 4A, and then goes back to 2A when I switch back to Normal.
silva10
South Carolina
2016 Ford Fusion and 2019 Hyundai Sonata
If I set mine to 4A(normal mode), it never turns back to 2hi when the truck is turned off/on. But if I select "sport mode" or whatever mode that sets it to 4a, when it is turned off/on again it switches back to normal mode 2hi.
pkinneb
Paul
Zimmerman MN
hmm I'll have see what happens the next time we get snow
