GABAR
The parts department of any Ford dealer.Where can you buy a grille from another trim?
Can you snap a picture from the front in daylight? is there any offset on the wheels? Want to do something similar but don't want too wide of a stance.Mods list:
4x4 5.0 LeadFoot XLT 302
Swapped my XLT grille for a Lariat one (picked up for costs). Like to think I’m one of the first to install raptor lights on the new 21’.
2.5” level kit
18” Method Wheels
Toyo AT II 295/70R18 34's
Stubby antenna
Ford Bedliner
Before installing Raptor lights.
make sure you order from Ford Parts online, choose your local dealer for pick up - it will save you hundredsWhere can you buy a grille from another trim?
Mods list:
2.5” level kit
18” Method Wheels
Stubby antenna
Ford Bedliner
Any tire rub running those 295/70’s?Mods list:
2.5” level kit
18” Method Wheels
Stubby antenna
Ford Bedliner
Pretty similar to the 2018-2020sLooks great bud!! How bad was grille swap? Want to put an STX grille in my XLT when it gets built and wondering how bad the tear down is
no rubbingAny tire rub running those 295/70’s?
I hooked up to the front side marker lights out of the driver side headlight. Easy two wire plug that was simple to identify what was ground and powerLove the Raptor lights............I have a 502a Lariat incoming.....How did you do the Raptor lights?
I believe it’s +18. The are method 305sDo you know the offset on your wheels? I'm still up in the air on replacing my stock 18's.
Yea pretty close to previous model. Lower fascia is removed by the two screws in each front wheel well. And there’s a lot of tabs on top of the grille/radiator plastic cover that hide other bolts/etcLooks great! I’m also curious about how the grill comes off. Is it similar to the previous models? The painted piece under the grill has two screws on each side and then pull it away from the truck, exposing the bolts for the grill?
Bought some Tacoma ones on Amazon that were a little wider to emulate the new longer lights on the new raptor. Spliced into the side marker light located behind driver side headlightWhich amber light kit did you use? Did you use a plug and play adapter or did you have to splice ? Looks great.
They were on Amazon. Just got some Tacoma lights that were wider/longer looking to closely emulate the new gen 3 raptor lightsNice truck! Where can I get the raptor lights? Thanks!
