Low Battery - Heater Not Working
Aonarch
North GA / MT
'24 V8 XLT 302a BAP, Tow | '22 Mustang Mach 1 | '25 Wrangler JLUR
Motorsport Engineer
To clarify, truck didn't sit for two weeks, drove it every other day. Just the USB drive was in for two weeks
Which is why I think you should go ahead and grab a H8 battery before you get stranded.
The center console is the only one that is hot after turning off the ignition. It does use the BMS, so will turn off once a certain voltage floor is met.
Sounds like you drive every day and have a 35 minute commute? That is plentlyyyyy of driving to keep the battery charged.
Davexxxx
MO
Console under the dash?
Still on a timer?
2515050
MT
2025 F150 RCSB 4x4
Has your truck received this OTA update? It may help as well:
Priority Update - Power Efficiency
09/17/2025
Vehicle Communication
This update improves background communication for your vehicle, helping to reduce battery drain.
BCMC-25.13.06
You can check here using the same login info as the Ford app: http://www.ford.com/support/software-update-release-notes-history
gagliano7
Joe
Monroe NY
I have to drive for at least an hour before mine is fully charged. I drive 25 minutes to work everyday and the volts stay at 15v the hole ride.
