Leveling a 2024 F150
Glen1027
Glen
Regina Saskatchewan Canada
2024 F150
I want to level my 2024 F150 but I don’t want to raise the front I want to lower the rear.
Has anyone taken out the rear spacer that’s between the leaf springs and the axle?
FerdBerfal
OK
'25 RCSB
Pretty common for the 4x4, it's truly as straightforward as it looks. Some folks do switch to the 2WD U-bolts afterwards so there's not so much thread dangling below. It wont get you perfectly level, for that you will want some lowering shackles as well, but that also needs a wedge shim to rotate the rear end back to level (both with or without removing the blocks)
