Left Side Height Level Sensor - DTCs & problem with new sensor calibration
Biorante
Rafal
Texas of Europe (aka Poland)
Ford F-150 Lariat 2021 SuperCrew V8
Hello,
I had a problem with the left side height level sensor, which returned a DTC with a wrong signal, and the local dealership confirmed that it was broken as re-calibration was solving the issue until the car went/off.
I bought this sensor: https://www.ebay.com/itm/375283775526
Replaced it and got a lot of DTC's which I don't know if are related to a broken sensor, a bad wire, or just missing calibration. I tried to do HCM calibration through FORScan, but it always drops the "high voltage" error. I checked my battery, charged it to 90%, and the voltage was still visible as 14V both for HCM and battery voltage.
Any ideas on how I can handle it?
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration hcm_check
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration 1744707022449-tf
Code:
Module: Headlamp Control Module
===END HCM DTC C1A03:29-0B===
===HCM DTC B1041:04-08===
Code: B1041 - Levelling Control
Additional Fault Symptom (:04):
 - System Internal Failures
Status (-08):
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
===END HCM DTC B1041:04-08===
===HCM DTC B1041:54-0B===
Additional Fault Symptom (:54):
 - Missing Calibration
Status (-0B):
 - DTC Present at Time of Request
===END HCM DTC B1041:54-0B===
===HCM DTC B1437:87-08===
Code: B1437 - Left Levelling Actuator
Additional Fault Symptom (:87):
 - Missing Message
Status (-08):
===END HCM DTC B1437:87-08===
===HCM DTC B1439:87-08===
Code: B1439 - Right Levelling Actuator
 - Missing Message
Status (-08):
===END HCM DTC B1439:87-08===
===HCM DTC B1D64:87-08===
Code: B1D64 - Left Headlamp Swiveling Motor
 - Missing Message
Status (-08):
===END HCM DTC B1D64:87-08===
===HCM DTC B1D65:87-08===
Code: B1D65 - Right Headlamp Swiveling Motor
 - Missing Message
Status (-08):
===END HCM DTC B1D65:87-08===
Old front left sensor:
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration Zdjęcie WhatsApp 2025-04-15 o 09.31.55_aa4966b7
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration Zdjęcie WhatsApp 2025-04-15 o 09.31.57_46fb80aa
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration 1744706734735-f3
SilverPigeon
Australia
Is the right hand sensor the same part number? If so, swap them and see if the calibration fault moves to the right. If it does, the sensor is faulty.
Biorante
Biorante
Rafal
I am more than sure that some of these DTCs are occurring just because calibration is missing. I tried two days in a row, and I have no idea what I need to do or how long I need to have the engine turned on to get rid of "Sensor Left: Voltage High!".
This just aborts the HCM calibration.
SilverPigeon
Australia
I maybe being misled by it saying "Front right OK". So it may be that voltage is reported high on the left headlamp itself. I've reached my limit of knowledge, obviously ?‍♂
Biorante
Biorante
Rafal
No worries. It got me the first time, too. Just went to take photos. no sensor on the right side!
Left front:
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration left-front
Right front:
Ford F-150 Left Side Height Level Sensor - DTCs & problem with new sensor calibration right-front
Both lamps are working well. The only thing that I also reported yesterday, that when I was using HCM monitoring in FORScan, the Swivel values were changing only when lights were on "automatic" but didn't change values when it was manually turned on to "short beams".
Biorante
Biorante
Rafal
@SilverPigeon could you drop me a photo of your sensor?
I connected the old one today, and the same DTCs occurred. It's weird because it showed the one DTC from HCM about calibration, and now it goes wild. Maybe the whole module is f*cked.
Biorante
Biorante
Rafal
I just got my new front leveling sensor, and unfortunately, it did not fix the problem. I am still unable to calibrate the sensor, but I got some new DTCs.
I checked the Voltage, and everything seems to be fine. I am out of ideas.
HCM Module Self-Test
Code:
(OK) [13:49:43.185] On Demand Self-Test has been started
(WARN) [13:50:00.413] Test completed, found DTCs: C1A03:29, B1041:54
===DTC C1A03:29===
Code: C1A03 - Left Front Height Sensor
Additional Fault Symptom:
 - Signal Invalid
Module: Headlamp Control Module===END DTC C1A03:29===
===DTC B1041:54===
Module: Headlamp Control Module===END DTC B1041:54===
HCM Alignment Calibration Errors
Code:
(OK) [13:39:28.624] HCM Headlamp Alignment And Calibration has been started
(ERR) [13:39:31.276] Front left: Voltage Low
(OK) [13:39:31.276] Front right: OK
(OK) [13:39:31.277] Rear left: OK
(OK) [13:39:31.277] Rear right: OK
(ERR) [13:39:31.298] Service procedure has been interrupted
DTCS
Code:
===HCM DTC C1A03:12-08===
Additional Fault Symptom (:12):
 - Circuit Short To Battery
Status (-08):
===END HCM DTC C1A03:12-08===
===HCM DTC C1A03:29-0B===
Additional Fault Symptom (:29):
 - Signal Invalid
Status (-0B):
Status (-08):
Status (-0B):
 - Missing Message
Status (-08):
 - Missing Message
Status (-08):
 - Missing Message
Status (-08):
 - Missing Message
Status (-08):
===HCM DTC U0126:00-08===
Code: U0126 - Lost Communication With Steering Angle Sensor Module
Status (-08):
===END HCM DTC U0126:00-08===
===HCM DTC U0151:00-08===
Code: U0151 - Lost Communication With Restraints Control Module
Status (-08):
===END HCM DTC U0151:00-08===
SilverPigeon
Australia
All I can suggest at this point is to check the wiring to/from the sensor to/from the HCM as well as all the HCM connections. If all that checks out, either try a swap with another HCM or see if calibration succeeds in FDRS instead of FORScan. Either way I'm thinking you need to spend money 🤷‍♂️
Biorante
Biorante
Rafal
Will investigate it further. I don't have FDRS but was thinking about getting cable (moongoose?).
