deanbychkowsky
- First Name
- dean
- Joined
- Oct 4, 2025
- Threads
- 1
- Messages
- 4
- Reaction score
- 0
- Location
- manitoba canada
- Vehicles
- 2024 f150 screw 5.0
- Occupation
- mechanic
After reading every thread I can find on upgrading the B&O 8 speaker system in my 2024 f150 I’m more confused than ever.
What I would like to do is add an Lc5i pro, replace the door speakers with coax Rockfords and power them off a 5 channel amplifier.
The questions I have are:
can I leave the center channel powered off of the B&O amp and the tweeters powered off the head unit if I do this?
do I need to make any forscan changes to run 2 way coax’s in the doors?
can I run the oem subwoofer off the new 5 channel amplifier until I decide what route I’m going for a subwoofer/enclosure? Obviously I’d have to turn the gain/bass boost on the amp down for the sub as it would be a 350w rms channel on the amp I’m looking at.
if this all worked I might not even tie up any space with another subwoofer as adding more power to better door speakers as well as block off plates might be enough to make me happy with the system. I was looking to run Rockford t1650 an t1692’s for door speakers and a Pioneer gm-dx975 amp (75w rms x 4 and 350w rms x 1)
My problem with the system is the bass rolloff and garbage speakers that distort at high volume, a lot of my listening is between 25-max volume and it sounds like trash.
I also considered running lower powered more efficient Rockford prime speakers in the doors off of the factory B&O amp and just using and l2ci pro and a mono amp/single under seat 12in subwoofer, but I’m not sure what the better direction would be.
