Installing mud flaps on 2024 F150 XLT?
Hot wheels
Rick
White Bear Lake
2024 F150. XLT
I did not receive the j item with the parts. Is this a shim of some sort ? Also the support brackets on both sides have a slight amount of play. Any ideas ? Thanks​
oncechance
Indiana
You will need a spacer between the aluminum and steel, which is the plastic shim you are missing. Steel and aluminum do not mate well. Not sure about the play you mention.
