I think I found my phone mount
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
discothan
SW Michigan
2021 F150 XLT
Very cool! 20mm ball means you can marry these to other phone mounts, like magnetic ones or even GoPro type mounts.
Merccat
Ryan
California
2021 Space White Lariat SCAB 5.0 4x2
I’ve used an air vent clip for years, they are great! This one looks like a little different design and I really like how it allows you to still have easy access to control the vent, if my current one ever breaks I’m gonna try it, thanks!
PungoteagueDave
Dave
Tesla MX, Porsche C4S, Ford F-350 KR, Ford F-150 K
Quadlock mounts and cases are the best available - we use them on everything from our bicycles, to motorcycles (have been around the world, across the Andes eight times, through Africa, to every major word cape), to all cars and trucks, to our desks, and bedside stands. Nothing comes close. There are versions with built-in charging, special versions for bikes and motorcycles, all mounts, and custom cases for every phone model. Not “selling” just experienced with many alternatives, found these life-changing on multiple round-the-world adventure trips. https://www.quadlockcase.com/
YzermanTopShelf
Tom
California
2021 F-150 Lead Foot Lariat Powerboost
@Heavishot thanks for the pointer. I went ahead and ordered one. Finished a road trip from SF to SD and it worked great. Definitely recommend it.
Ford F-150 I think I found my phone mount 7FA2C409-3DCA-4E17-AE07-7A9F8F939138
Tjbev13
'21 F150 XLT 302A, 3.5EB, Max Tow, FX4
Turner of wrenches
Wish it could just have a shorter arm and simple magnetic mount
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
CommoSGT
Ken
Kentucky
2016 F150 Lariat SCrew V8
I think you can buy the base alone then add to it. I plan to get the base with a 20mm ball and then us an adapter like this then attach my mount to that plate.
Heavishot
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
I ended up going with the OffRoam mount paired with a medium size Ram extension bar, 25mm to 17mm ball adapter and an iOttie wireless charger. I tried to use the Ram wireless charger but it would only charge my iPhone 12 Pro Max with the case removed. The iOttie works if you extend the feet at the bottom.
The setup is pretty solid. One note on the iOttie is that it comes with a cig adapter plug not a USB so you will have to supply your own cord. Maybe one day I'll get around to hard wiring it.
Ford F-150 I think I found my phone mount IMG_2982
Ford F-150 I think I found my phone mount IMG_3025
Ford F-150 I think I found my phone mount IMG_3026
BHunted1
Sumner County TN
Go one as well with 1" ball and installed on left. Going to get another with 20mm ball for the right side. Got the 1 on the right now with a short arm and Safemag charger. Works great.
Ford F-150 I think I found my phone mount vent1
Ford F-150 I think I found my phone mount vent2
Knickell
Mazda Protege, Ford F-150
I'm pretty big on my ice cold A/C. If it blocks my vents, its a NO from me....
Ford F-150 I think I found my phone mount 16C50C61-C574-440A-8763-E611E7E0B226
RexTX
Rex
DFW TX
2007 Mustang Shelby GT, 2008 Ford Escape Hybrid
I use the Steelie mount. Best thing I have found. I use the Otterbox case which has a thick back. I drilled a hole to fit the magnetic piece so it sat flush. It's quick to attach and remove, holds securely, and is pretty minimalist.
