ImChris
- First Name
- Chris
- Joined
- Dec 19, 2022
- Threads
- 5
- Messages
- 69
- Reaction score
- 191
- Location
- Madison WI
- Vehicles
- 2022 PowerBoost Long Bed
- Occupation
- Commercial Photographer
Sharing my deepest, darkest secret with everyone in the title! After years of running a couple different setups in my Toyotas (rooftop tent for 5 years, truck camper for 2 years), while on the search for a newer truck camper we came across a Scamp. After some chatting and a lot of convincing from my wife, we now have a little 13ft guy to pull around everywhere!
To add a little seriousness to this post, I'd never considered a trailer as an option because I spend a good majority of time on offroad trails when camping. Rustic, dispersed sites are usually as close as I get to a campground and I figured a trailer would hold me back. Plus it would add a little inconvenience if I needed to back down something narrow.
Here is where we landed and some talking points if anyone is curious:
You can probably see from the photo the Scamp is VERY low. I actually took it down some two-track for the video you see below and we hit some things often (but no damage). They use a torsion bar setup and ours is totally worn out. I have a new, adjustable torsion axle in the garage and larger tires that should give me a solid 6+ inches of lift. The torsion is also 'leading arm' and I'm changing it to a trailing arm setup which should smooth out pulling over rough terrain a lot. The nice thing about a torsion setup is the main axle is mounted almost up next to the body and the 'arms' extend down right next to the wheels (almost like a portal axle kind of) so you don't have an axle hanging low across the body to get caught on things.
I'll update the build progress on the scamp and my bed build out here as things get moving! Here is a rough idea of where I'm heading
Here are some details on my truck and the scamp if you're curious:
-Chris
- For the majority of time(s) that I'm camping with my wife and dogs, we're on tame, two-track type trails. We're not trying to push it or risk-it-all and possibly break something on the truck that could ruin our trip or get us stuck someplace. For this, a small trailer isn't much of a hold-back.
- I'm based in Wisconsin and 'free camping' is limited, mostly in the UP of Michigan. Since those off-grid areas are hard to come by, when you get a good one you want to keep it. We've ran into a few scenarios where we've wanted, or needed to head back into town after a couple days off-grid and knew if we left our spot would be gone when we returned. A trailer allows us to unhook and keep the spot. (We've previously brought a single person tent to 'hold' spots but onetime we came back and it was missing! ha)
- IF we want to explore more rugged trails, the Scamp can act as a basecamp of sorts and we can venture out from there, without the trailer.
- When I'm solo camping, which I do often for work which brings me around the country a lot, I'll do a very mild buildout in the bed and sleep in there. I'm selling my softopper and going for a SmartCap to start this solo build out.
- New Scamp suspension + light frame reinforcement + changing to 2in ball
- Scamp exterior work (new seals, replace some windows, caulking, replacing rivets, paint, etc)
- Scamp interior revamp (floor is solid, this is all cosmetic upgrades to replace a lot of worn out interior pieces)
- Truck bed build out: SmartCap, single side full length drawer, sleeping platform/cot
- 22 Powerboost
- Bilstein Ford Performance full coilovers (set at 2.5)
- KMC Impact 17x8.5 +18 wheels on 285/75/17 Open Country ATIIIs
- ^^^ Now on 285/75/18 Falken Wildpeaks w/ 18x9 +12 Black Rhino Chamber
- Ford Performance Blackout Lariat Grill
- SCAMP
- 1982 Scamp 13ft, weighs around 1200lbs
- I have a EcoFlo Delta Max with 400 watts of deployable solar. I plug this into my truck and if it ever gets low, quick charge it up!
- The EcoFlow runs all things in the camper, charges all devices (I'm a commercial photographer, I charge a lot of stuff!), and runs our two electric fridge coolers
-Chris
