Would there be any benefit to someone with an XL installing one of these? I'm guessing more hardware would be required for things like dual zone to function, but honestly if just the auto function worked it would be something I'd consider doing the swap for.You can use the same module. You will have a DTC if its never been in a truck before.
The software is different in different years. BUt it seems to not matter in the performance. BUt if you care about DTCs then youll want it flashed.
It will work. As you said no Dual. Youll be missing the Solar sensor also. You can add it pretty easy.Would there be any benefit to someone with an XL installing one of these? I'm guessing more hardware would be required for things like dual zone to function, but honestly if just the auto function worked it would be something I'd consider doing the swap for.
