Evolvd
1. No. Unless it’s a specific acidic or alkaline formulation for a specific task (water spot remover, iron remover etc) then it should be safe for all surfaces.
- Are there any surfaces or materials (elastomers, rubber, plastic, chrome, PVD Wheels, etc.) that you shouldn't put a Ceramic Spray Coating on?
- Any solutions for keeping the bugs out of the water while you are trying to dry?
- I also get a lot of bugs on the front camera, hood, grill, and windshield while driving. Any solutions to improve that or make it easier to get them off?
I found these videos in case anyone is interested:
The high pH car wash soap concerns me a bit for the top 2 results.
I’ve Never Seen A Snow Foam Car Wash This Good!
I've Never Seen A Ceramic Coating This Good! Not Even Close!
I've Never Seen A Plastic Car Trim Restorer This Good! Wow!
2. Can’t say I’ve ever heard of this issue before.
3. Use a dedicated bug remover like CarPro Bug Out. Spray it on the carcasses or gut spots and let it dwell a minute or two. Then you can foam over it, or hand wash it. If it’s a stubborn stain don’t go overboard scrubbing it as you’ll likely mar the paint around it. If chemicals won’t remove it then it’s time for polishing.
As for your videos, PH balance is not what determines a chemicals harshness. It can be an indicator but not the full story. For instance, Car Pro Iron X is a sledgehammer iron remover. If you let it dry on the surface it can cause issues….and it’s PH neutral.
