Help with IPC module - can't complete PMI - mismatched firmware
dsaturday
Dom
Hello,
I bought a 2021 F-150. I noticed that it had all of the necessary hardware for BC. Installed all FDRS updates. However, the IPC module is throwing a GVMS warning. Upon looking into this further through the vehicle history in PTS, it appears that somewhere along the lines a dealer may have screwed up the IPC update. The truck was in the shop for 3 days in April 2022, and every time the dealer tried to run IPC module updates, the following error occurred:
Procedure unsuccessful - ReadFlashActionDIDsFromModule Update was not successful FAIL - F120 = ML3T-14C026-CDL>>> should = MU5T-10F906-FDA
PASS 188 - MU5T-10F906-FCA
Then it looks like the dealer just gave up.
Reviewing the connected vehicle history, the truck for years has thrown the U2100 codes for the IPC. I suspect this prevented it from ever getting OTA updates. And it is currently preventing me from completing all of the steps that I believe are necessary to active BC and finalize all the modules.
When I try to run PMI on the IPC module, FDRS throws the following error: Procedure Unsuccessful -Get Flash Action Part Numbers Unable to obtain Flash Action part numbers from Restore Topology.
Am I wrong to suspect that this is what's triggering the GVMS warning and locking out any IPC updates?
F188 appears to have updated correctly to MU5T10F906-FCA but F120 is misaligned with the old software (ML3T-14C026-CDL).
If I can't run PMI on the IPC module, how do I get the MU5T-10F906-FDA file and how do I flash that into F120? Right now, the IPC modules DID block isn't matching what Ford servers expect for my VIN.
Any help would be greatly appreciated!
rugedraw
Javier
Miami
Auto Sales
We can side-load it with FORScan. I have the files. However, an IPC update via CAN will take every minute of 6 hours to do. FORScan will not create a USB update for the IPC.
dsaturday
Dom
As you can see, the dealer claimed to have performed FSA : 21G01, but screenshots from PTS show that the IPC module failed every time they tried it over the course of three days or so.
I assume this is why BC functionality will not work despite all of my other modules being up to date and passed through FDRS.
Ford F-150 Help with IPC module - can't complete PMI - mismatched firmware Screenshot 2025-07-21 at 5.15.42 PM
Ford F-150 Help with IPC module - can't complete PMI - mismatched firmware Screenshot 2025-07-21 at 5.14.31 PM
Ford F-150 Help with IPC module - can't complete PMI - mismatched firmware Screenshot 2025-07-21 at 5.15.27 PM
dsaturday
Dom
You are a lifesaver. But I will need walked through this. Especially since it's a long update. I thought IPMA and CMR were long! 6 hours is insane. But if it gets my truck working correctly, I'm willing to do it!
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
I’m far from an expert but the GVMS should have a link to submit on the IPC page to Ford and their engineers will review in 3-5 days and that could help clear up your conflict issue and perhaps allow you to then update the IPC in the future. I had that error on an ABS module on a different Ford vehicle and they cleared up the conflict after I reported it. Something to do with a mismatch in the As built data at least in my case. Yours sounds more complicated than mine so it may be beyond the simple fix I got done by submitting the link to Ford. Hopefully someone more knowledgeable than me will update/clarify what I said about the GVMS.
dsaturday
Dom
For some reason, you have to have a dealer login to create the ticket. When I ask to create the ticket, I can’t login to page it directs me to with the same FDRS credentials.
JohnTrigger
MD
I was able to create a GVMS ticket about 3 weeks ago, but that was two FDRS updates ago, so maybe it’s changed. I don’t know
