Grill swap 24 stx to 23ish Limited?
Brian
Rockport tx
2024 f150 stx, 1979 chevy c10.
Discount tire.
New to the form, hello, would like to know if it is possible to put a 2023 limited grill (and maybe headlights) onto a 2024 f150 stx.
I know it is possable to do a lariat grill swap for a 2024. However you can't go any higher without getting a new hood.
But looking at the 2023 limited grille it still appears to have the little bomnet.
So is it possible? Or is the mounting completely different. And does anyone know how to adapt the stx headlights(led) to the higher trim ones.
Making a thread cause all the ones I can find are from when the 2024 were first released and not many people knew much.
Je1279
Jared
Upstate NY
The '21-'23 grilles were interchangeable so if it works for a Lariat it should work for a Limited as well. Im guessing you may also need some '21-23 headlights and possibly other parts as well. I do not know if all of the higher end headlight modules will work with the '24+ trucks, but if so, it may also require custom wire harness adapters and some Forscan changes.
Brian
Rockport tx
Discount tire.
Anyone got more info on this?
