GhostRiderF150's 2023 Carbonized Gray BAP Build
GhostRiderF150
GhostRiderF150
2023 F150 Lariat 5.0 Coyote BAP
I took my truck in for an oil change and I had them remove the rear 4x4 decals while I was there. It was kinda odd at first but now that I've had it done for awhile I'm liking the cleaner look.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000007354
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000007360
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000007359
MattV
Matt
US
Cadillac CTS-V, 2023 RCSB F150
Very nice setup! Great color for BAP.
GhostRiderF150
GhostRiderF150
GhostRiderF150
GhostRiderF150
I decided I wanted to upgrade the halogen license plate lights to LED. I wanted a cooler crisp white color to match the the rest of the truck.
I first tried the Morimoto XB lights. This replaced the entire housing unit instead of just the bulb. It was simple to install and only took about 5 minutes total with no tools.
Left side is original stock and right side is the new LED housing. I wasn't crazy about the gloss black look vs the stock housing but liked the color.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240115_012226
Both installed. They were really bright.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240115_012656
After driving around at night for a few hours I couldn't stand the glare it produced on my rear camera screen. It totally flashed out right below the truck a few feet.
After doing some research online my wife found me a LED replacement bulb from Diode Dynamics. They offered the 194 bulb in 3 different brightness levels for the 6000k cool white. I went with the lowest SMD2 which they say is 24 lumens. And I was able to use the stock housing units.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240115_015428
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240115_011920
Very happy with the new bulbs. Rear camera works great again and the color is great.
GhostRiderF150
GhostRiderF150
I also got the rubber bed mat for free with my ford pass points. It came in a little dirty but it fit great and will help protect the sprayin bed Liner.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20231225_153955
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20231225_153950
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20231225_153927
GhostRiderF150
GhostRiderF150
We finally got some decent weather here today.. mid 60s.. so i did my first wash with a foam cannon. I gave it a good washing with the pressure washer and then hit it pretty hard with the foam. I let it sit about 5 minutes then hit it with the pressure washer again.
I then decided to give it one more cleaning by hand followed up by a light ceramic coating. Pretty happy with the results.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010364
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010368
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010369
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010370
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010371
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 1000010372
GhostRiderF150
GhostRiderF150
Added a Morimoto X3B LED Third Break Light. Install was pretty easy.. I broke one of the white tabs to help hold it in place but its been fine. That was the biggest pain.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20231231_173437
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240101_115142
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240101_115217
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240101_115431
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240101_115458
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240102_093948
GhostRiderF150
GhostRiderF150
I finally pulled the trigger and ordered my lift and wheel/tire combo on black friday and install was scheduled this week. It took two days but they did a great job and I'm very happy with the results.
I went with the 4" BDS lift with Fox 2.5 P.E. Coil-Over and Fox 2.5 P.E. 3" rear block. I've only put about 30 miles on it and we are in the middle of ice and snow, but so far I'm loving it.
First look.. yea I was pretty nervous haha.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_154704
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_154959
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_155103
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_154900
GhostRiderF150
GhostRiderF150
Front.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_163133
Rear.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_163400
GhostRiderF150
GhostRiderF150
For wheels and tires I went with Toyo Open Country ATIII 35"12.5R20 and Fuel Assault 20x9 +1 Gloss Black w/Milled Edge.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250110_154722
GhostRiderF150
GhostRiderF150
Wife following me home after picking up my truck. She was taking photos from behind to show me when we got home. #winningatlife when your wife is your best friend.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build IMG_4947
GhostRiderF150
GhostRiderF150
Still filthy from the roads.
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250113_093832
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20250113_093841
Graygoose2021
Oklahoma
Sales
Beautiful build.
Yes, happy wife, happy life!
Now you have the fender wheels showing, check out the Chemical Guys Bare Bones...stuff is magic, once winter is over :)
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240525_124634_resized
Ford F-150 GhostRiderF150's 2023 Carbonized Gray BAP Build 20240525_124655_resized
Groovicles
2022 F150 XLT 302A PB Max Tow
Finance
I removed the decals as well on my '22 and I think the vehicles look great without them. Awesome build man, truck looks fantastic.
