FORScan windows laptop
Lricaud81
Louisiana
2023 f150 stx fx4
So I just figured out our laptop is a chromebook so its not windows. I believe I've seen here you need a windows laptop to do FORScan . And I saw someone on one of the many threads posted a cheap windows laptop to use FORScan on. Anyone know this or know of one thats cheap but works good with FORScan. I don't wanna spend alot since the absolute only thing it'd be used for would be FORScan.
Once I get out of terror of using FORScan I can possibly change some things on my truck. Lol
Kanuck
Winnipeg, Manitoba
Retired Electrician
Off topic - I have an old windows 10 laptop that I use for both FDRS and Forscan only. Also, all my information I have gathered from this forum...LOL
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
I'm terrified of FORScan. I'm not tech savvy at all. But I've been reading posts on here thinking I may jump in. But then I notice my laptop isn't usable.
Kanuck
Winnipeg, Manitoba
Retired Electrician
You will need and ODB2 connection of some sort. I have a Mongoose so I use it for FDRS and Forscan. There are a few OBD2 connectors listed on the Forscan site. One I believe was designed to work with Forscan.
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
Yeah I have one in my cart that I saw on one of the threads. I'm just looking to find a great deal on a compatible laptop since mine isnt compatible. Chromebook isn't windows
Kanuck
Winnipeg, Manitoba
Retired Electrician
I know buying a used laptop is a gamble unless you get one with a warranty or something. Maybe a local computer repair shop has one that would work. Would not need a high power unit. I would not want to get one from a ad on line.
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
Thats what makes it so bad I want one that'll work but doesn't have to be fancy. Scared of those refurbished ones my luck it'd crash as I was trying to do something and brick my truck
Kanuck
Winnipeg, Manitoba
Retired Electrician
I don't think that would happen if it crashed. It would just not complete the change. Message @Snakebitten and ask him. The biggest thing is to back up the file before making any changes. I did it one change at a time. Tested it out. Then did another. Lots of good people on here that would help you out.
A cheap Windows laptop is $200-300.
Walmart or other stores have them.
First thing I did was clean install Windows without all the garbage it came with, then install Forscan and FDRS.
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
These say they run windows
Ford F-150 FORScan windows laptop Screenshot_20240328_190341_Walmart
Ford F-150 FORScan windows laptop Screenshot_20240328_190448_Walmart
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
Nothing fancy absolute only thing used for would be FORScan. There like $60
Kanuck
Winnipeg, Manitoba
Retired Electrician
I had been using mine for a few years. So when it was replaced, I went through and deleted all the programs but what I need.
Lricaud81
Lricaud81
Louisiana
2023 f150 stx fx4
Kanuck
Winnipeg, Manitoba
Retired Electrician
That's what you say now.... then it is ...well, lets give FDRS a shot. Oh, look, more Forscan changes. You will get the bug and it will not stop...:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:. We all had this happen.
