F-150 Hitch Receiver Weight Capacity
turbopilot
Prescott, AZ
2023 F150 Powerboost
Just reread the 2025 F Series towing Guide. Setting aside the suggestion to use a weight distribution hitch on an F-150 with a trailer above 5,000lbs, does anyone know why the Hitch Receiver Weight Capacity is so restricted when not using a weight distribution hitch? Given the heavy weight of the WDH's and the stress imposed by the bars and chains to set the 50% FALR recommended by Ford, I don't understand this weight restriction based on the inherent strength of the hitch and hitch attachments to the frame. Increasing the maximum hitch receiver weight by 850 lbs just by the presence of a WDH without any regard for the tongue weight or trailer weight (except the max trailer load of 13,500lbs) just makes no mechanical sense.
Ford F-150 F-150 Hitch Receiver Weight Capacity HitchWeight
moritzes
Stewart
2025 F-150 Lariat PB 157" | 2025 Mustang Mach-E
Strange. Maybe someone was conflating the idea of the tongue weight needing to be at least 10% of trailer weight? It's just too convenient that 1350 is 10% of WD max trailer capacity and 500 is 10% of non-WD max.
Sparkybrent
Brent
Utah
2021 F-150 Lariat LB
Electrical Contractor
I agree it makes no sense. When I researched this, it was pointed out by a reputable hitch installer in the Salt Lake valley that the hitch structure is not simply a bolt on to the frame unit like in years past. It is actually part of the bumper support assembly and exceeding the 5k lb carry limit would compromise the bumper. I still don't see how a WDH would change that, but I had to abide, by getting another one for my 8k lb boat.
ApolloChurchill
San Antonio
F-150 Tremor
The limit is there because it is the safe maximum before you are shifting too much weight to the rear of the truck, thus less weight over the front axle which affects the stability to control the vehicle. The further away from vehicle center you go, the less weight it takes to affect all these things, and the hitch is the furthest rear point. A WDH actually uses forces to counteract this cantilever effect which is why the limit goes up.
turbopilot
turbopilot
Prescott, AZ
Yes, but the F-150 comes in a wide variety of trims and weights. Drawing the line at 5,000 lbs may be simple but probably is very conservative depending on the F-150 model.
ApolloChurchill
San Antonio
F-150 Tremor
Very smart to just rate at the minimum if you’re going to throw a broad number on a vehicle, from a manufacturer stand point. Your tongue weight limit is supposed to never exceed 10% of the trailer weight so that’s the variable that’s more appropriate for the build specifics
turbopilot
turbopilot
Prescott, AZ
But that is where this all gets silly since trailer manufacturers suggest tongue weights between 10% and 15% of the trailer gross weight for stability. 10% is right on the edge of a "light" hitch.
Chris GTO TT
Lincoln CA
2023 F-150 XLT 302a
Just wait it gets even sillier. On the 21-23 trucks (possibly older too) if you didn't get the trailer tow package or the max tow package you could tow up to 7000lbs or 700lbs of tongue weight without a weight distribution hitch. With either of those packages you're limited to the 500 or 5000 as mentioned in this thread.
Buyer2021
central TX
retired!
This is the sticker for my OE receiver showing a maximum GTWR of 14,000# with WDH.
Ford F-150 F-150 Hitch Receiver Weight Capacity RECEIVER STICKER
BUT, the applicable towing guide for my truck as equipped shows 12,300# as the maximum conventional towing GTWR.
When I add 12,300# to my truck's curb weight as delivered (measured on a CAT Scale), the sum is very close to the GCWR listed in the towing guide.
Quite a coincidence, eh :wink:.
Whatever / No Worries, I'll never approach any of these limits with my use of the truck, the 5th-wheel I tow is far below any of the applicable limits for that trailer type. (y) :)
(truck& trailer described in my signature block below)
