TexasTruck
My truck has the factory trailer tow, not the tow tech or tow max packages, but still. I need to add a trailer brake controller (TBC). When I look under the drivers side dash/kick area, I see what resembles the TBC black box on the far left, it has a grey and black connector. When I remove the coin holder, there is a connector for the TBC +/- and pinch slider control.
Assuming that black box is not a TBC without the dash switch, I ordered TBC part number ML3Z-19H332-AB which replaces ML3Z-19H332-AA. The kit has a new black box and a dash switch.
What I did:
-I replaced the dash coin holder with the switch that came with the kit. I did not RR my original black box with the one that came in the kit. I fired up FORScan, went to IPC and enabled the TBC, started the truck, a red message about a Trailer Brake Controller fault.
-Thinking the original black box is not a TBC, I RR it with the black box from the kit. Started the truck and no red message. I can press the +/- and see the gain value increase or decrease. When I pinch the slider Gain shows and a No Trailer message. However, in FORScan I see three DTC MIL messages.
I read here where other owners adjusted the TRM settings in FORScan. When I look at my values, they are almost all FFFF with the black box in the kit. When I did the same with the factory black box, I have "good" values. However, in either case, when I change one of the values and save it, I hear the black box click once, then I get a FORScan failed to update module error.
Why am I posting here, I'm just wondering if I need to enable the TBC with FDRS, to tell the truck it's there, then use FORScan. Maybe the module is unknown or something?
TIA
What I did:
TIA
